O/D Light is Blinking
Fraya713
2002 Mazda Protege5
So I was checking my fuses in my fuse box to see if any were bad.
I pull each one out, one at a time and then plugged it back in.
Started my car up and now I have a blinking Overdrive light.. any ideas?
Thanks all
How are your connectors for the MAF and Air Temp Sensor.
I had the O/D light flash at me a couple months ago when I was changing my MAF Sensor and forgot to plug the connectors.
Rub your code with a code reader (or disconnect the battery for ten minutes) and see if it comes back.
(your car will stumble for a while as it relearns if you disconnect the battery)
