CX-5 Multiple issues after unhooking battery
Bam_19
Hello
I have a 2014 Cx-5. The Bluetooth stopped working and I seen the common fix was to unhook he battery. So I did this and it didnt fix anything. So Im guessing its the module and Ill have to take it in.
But more concerning than that is when the wife was driving to work today the blower isnt blowing at all (no way to defrost this was working fine pre battery disconnection), the turn signal click sound is twice as fast as yesterday and he windows auto roll down doesnt work (though based on this forum it sounds like I just need to reset that).
Is it likely a fuse blew when reconnecting the battery?
What are other things I should check for before turning over my life savings to the dealership.
Often multiple issues like this are the result of a bad ground.
Since you unhooked the battery, the first place I'd check would be the battery terminals. Make sure they're clean and tight, then go from there.
Latest posts
