I swapped the motor out on my 5 and put a motor in that I heard run when it was pulled from the car now it will start but will die at low rpm if you hold In the gas just a bit it will stay running any suggestions?
I heard a slight sucking sound and started wiggling stuff came to the fuel rail and one injector was a little wet around it took it off and the seal that goes into the manifold was bad
