Page 1 of 7 123 ... LastLast
Results 1 to 15 of 94
Thread: Radar cruise control intermittently disabled below 20mph
  1. #1
    Registered Member
    2017 CX-5 Grand Touring
    Join Date
    Nov 2017
    Location
    Midwest USA
    Posts
    3
    I have a brand new 2017 CX-5 Grand Touring with stop and go cruise control. About 50% of the time I use the cruise control, I get this message: "Mazda Radar Cruise Control Disabled under 20 mph". The radar faceplate and the camera are both clean (I get a different message when they are obstructed). The dealership has checked the computer and found no errors or faults. There doesn't seem to be a pattern as to when it's disabled and when it's not, so I'm having trouble diagnosing.
    The manual (page 4-126) says this message displays when there is an issue with the forward sensing camera, an issue with the stop hold control function, or the electric parking break.
    Any ideas?
  2. #2
    Registered Member Xeler8ing's Avatar
    '18 Mazda CX-5 Akera KG i-Activ AWD 2.5L In Sonic Silver
    Join Date
    Apr 2017
    Location
    Down Under..Australia
    Posts
    8,991
    Do you have auto-hold enabled
  3. #3
    Banned GJ-Molestor's Avatar
    2011 BMW 528i, 2015 Mazda 6, 1995 Nissan Maxima Manual
    Join Date
    Apr 2017
    Location
    Toronto
    Posts
    1,798
    most adaptive cruise control systems don't work below a certain speed, so I would chalk it up to that but it doesnt seem to be the issue in this case.
    does the cruise control work fine at higher speeds?
  4. #4
    Join Date
    Apr 2017
    Location
    Posts
    8,991
    Quote Originally Posted by GJ-Molestor View Post
    Mazda's is as follows:
    The Mazda Radar Cruise Control with Stop & Go function (MRCC with Stop & Go function) system operates when all of the following conditions are met:
    Vehicle speed is 0 km/h (0 mph) to 145 km/h (90 mph)
  5. #5
    Registered Member
    Join Date
    Oct 2017
    Posts
    1,303
    I only use the cruise on wide open freeways. It seems as of late younger drivers use it all the time.
  6. #6
    Join Date
    Apr 2017
    Location
    Posts
    8,991
    Quote Originally Posted by Puyapim View Post
    Same here
  7. #7
    Registered Member Anchorman's Avatar
    2018 CX-5 SportNav 2.2 diesel auto - Sonic Silver
    Join Date
    Jan 2016
    Location
    Derbyshire UK
    Posts
    2,262
    I don’t have it but looking at this detailed info it would seem to me that although it has stop and go, it won’t reliably maintain operation at low speeds so it drops out. So, it will stop and go on the motorway but if you start crawling in traffic it hands back to the driver.
    Makes sense to me. You’d have somebody reading Facebook on the freeway before so long.
  8. #8
    Join Date
    Apr 2017
    Location
    Posts
    8,991
    Quote Originally Posted by Anchorman View Post
    I think not all the conditions are being met, hence the malfunction
  9. #9
    Join Date
    Jan 2016
    Location
    Derbyshire UK
    Posts
    2,262
    Quote Originally Posted by Xeler8ing View Post
    Agreed, well not even a malfunction but outside of the operating parameters.
  10. #10
    Join Date
    Apr 2017
    Location
    Posts
    8,991
    They still haven't advise if they are using Auto hold or not
  11. #11
    Registered Member
    Join Date
    Nov 2017
    Location
    Midwest USA
    Posts
    3
    I've gotten the error with auto-hold enabled and disabled, but I'm pretty sure that setting is independent of the stop and go cruise functioning. I'm using it on my highway commute, which is typically ~50-70mph but can be stop and go some days. The message will show right away when I enable the cruise control but sometimes it doesn't show up at all. At first I thought it was an obstruction of the camera (which runs the cruise under 20mph), but there's actually a distinct message for that, which tells you to clean/defog your windshield.
  12. #12
    Registered Member
    Join Date
    Nov 2017
    Location
    Midwest USA
    Posts
    3
    Oh, and yes, to be clear, the cruise works fine above 20mph (when the radar is running things, not the camera). If I'm reading the manual right, the issue may not be with the camera at all, though. My working theory is a software issue of some kind that fools the car into thinking the camera or the break isn't working correctly. My dealer was stumped (they'd never even seen the error before). They're going to follow up with the Mazda rep so I'll post here if I get any more info. But anyone else experiencing this and noticing any patterns would be helpful. The sales guy who sold me the car owns the identical 2017 model and has been getting the message, too, so I'm pretty sure it's not an isolated thing.
  13. #13
    Join Date
    Apr 2017
    Location
    Posts
    8,991
    Quote Originally Posted by mocx-5 View Post
    Auto hold does impact mrcc, so best to have it off during mrcc use
  14. #14
    Registered Member Srad600's Avatar
    2016 CX-5AWD GT+Tech/ 2018 CX-9AWD GT
    Join Date
    Jun 2015
    Location
    Chino hills, California
    Posts
    682
    So are you trying to initiate cruise control below 20MPH? I've never tried that personally, but I thought the intent was for the cruise to be initiated at higher speeds and then if you slowed or dropped down to zero it would continue and bring you back up to the set speed. I think you just need to be moving a bit faster in order to initiate the set speed? According to page 4-155 of the manual "With cruise control, you can set and automatically maintain any speed of more than about 25 km/h (16mph)."
    Sounds to me like you just need to speed up a bit.
    EDIT: FYI that page reference is from the 2018 CX-9, so the CX-5 page may be slightly different.
  15. #15
    Registered Member
    2004 Honda Accord EX
    Join Date
    Nov 2017
    Location
    Sacramento
    Posts
    9
    Quote Originally Posted by Srad600 View Post
    I have had my 2017 CX-5 GT for about 2 weeks now and this error showed up a few days ago. Before this error started I could set cruise control as long as i'm going above 20mph, and as long as I would do that MRCC would go all the way down to 0 mph. When it came to a complete stop it would autohold by itself even if you don't have autohold switched on. When the car in front of you begins moving again you lightly tap the accelerator and the MRCC will resume.
    I had been using MRCC like this with no issues in stop and go bay area traffic with speeds ranging from 0-35 mph. It worked great for me at the time. Now I get the same error message as the OP and when I initiate MRCC (above 20mph) and my speed drops below 20mph the car beeps at me and flashes the error message on the HUD as well as info gauge.
Similar Threads
  1. Mazda radar cruise control with stop and go
    By Artista in forum CX-5 Accessories & Appearance
    Last Post: 01-17-2019, 02:26 PM
  2. Mazda Radar Cruise Control question
    By tconner99 in forum CX-5 Lounge
    Last Post: 02-22-2018, 09:34 PM
  3. Radar Cruise Control - Low speed follow?
    By CanEngineer in forum CX-5 Lounge
    Last Post: 03-01-2017, 02:10 PM
  4. Mazda Radar Cruise Control
    By 14M6GT in forum Mazda6 Engine & Transmission
    Last Post: 01-29-2016, 09:50 PM
  5. Replies: 0
    Last Post: 06-17-2014, 11:27 PM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
