Thought I would share my latest and greatest. Only cost about 20 dollars total. I got the wireless charger from amazon. https://www.amazon.com/dp/ (commissions earned)
This one had one of the best reviews and it was also one of the smallest to fit into a tight space. The install wasn't that bad actually.
You just have to remove a few pieces of trim.. no screws at all. Just all clips. The side trim pieces to the left and right of the gearshift you just pull toward yourself and they pop off.
https://imgur.com/VeWrZDs
Then then you can remove the gloss black trim by pulling up (just clips). Lastly you can remove the control knob by pulling up on that piece of trim upward.
The actual plastic piece you see in tho photo is also held into the gloss black trim by two tabs underneath. just flip it over and push the tabs inward to release this trim in the picture.(the gloss black trim and cubby are attached but come apart I mean) Underneath the pocket, you have to use a sharp exacto knife and cut off the ridges to get the wireless charger closer to the plastic. I then use epoxy to glue the corners and a dot in the center of the wireless charging circle.
https://imgur.com/l6dRA63 https://imgur.com/9YIkioy https://imgur.com/tWqjiw1
It is being powered by USB from the accessory port I have routed from the front 12+input. But since its USB it did work plugged into the port for the radio. Im not sure if I would do this as I'm sure the power consumption might be too much or not enough causing slow charging or messing with the radio. https://imgur.com/9NxYhrl
