In Memory of Member 1338
Results 1 to 2 of 2
Thread: No heat 2014 Mazda 3
  1. #1
    Registered Member
    2014 Mazda 3
    Join Date
    Oct 2017
    Location
    Nashville, TN
    Posts
    1
    I got into my car this morning and turned my heat on. It worked fine. I got back into it after work and tried to turn The ac on but it was blowing straight heat. I turned all controls off. And tried to start over. It then started blowing ice cold ac. Well now it will not turn back to heat. It is ice cold air no matter where the dial is set. I have no idea what is going on. Any help would be great full. And any info on where said part that is broken is located. I believe the heat is still working but maybe the actuator for the flap is broken. Help!! I
  2. #2
    Registered Member
    mazda3
    Join Date
    Mar 2018
    Location
    canada
    Posts
    2
    these cars are known for the pivot arm failing and causing the blend doors to be stuck in position, the part is located behind the glovebox
Similar Threads
  1. Replies: 16
    Last Post: 05-02-2015, 08:46 AM
  2. 2014 Mazda CX-9 vs 2014 Honda Pilot
    By jcsammy68 in forum CX-9 General
    Last Post: 08-21-2014, 04:34 PM
  3. Replies: 1
    Last Post: 12-09-2013, 02:32 PM
  4. 2014 CX5 GT "Miami Heat" dealer edition.
    By Sargecx5 in forum CX-5 General
    Last Post: 11-14-2013, 10:52 AM
  5. Replies: 32
    Last Post: 07-10-2013, 11:22 AM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
