This handy little trick might help.
I spent 5 hours and had the damn belt on and off a dozen times before I finally got my teeth lined up (I didn't have a helper to hold the cams)
Channel locks holding a box wrench AND a crescent wrench? You sir have my approval....
people have broken belts at highway speeds and their engines were ok they're non interference engines
Actually its a non-interference engine that can evolve into an interference engine.
With time, the connecting rod bearings can wear at both ends allowing the piston to throw just a bit further and hit a valve.
It's very rare and I know of only two guys that bent their valves.
All the timing belt kits list our engine as interference.
i would either invest in an impact gun, or get a good chain wrench to break the crank pulley bolt loose. impact gun is best, but alternatively you can use a nice chain wrench around the pulley to break the bolt loose with a breaker bar....
Some guys had someone in the car holding the brakes on while in gear, to hold everything.
Or,... The fun way is to put the breaker bar on the pulley bolt, rest the handle on the ground (making sure it's on the correct side) then go and hit the key to start position for a second.
I threaded a bolt in where the SST would attach then wedged a bar in between for counter torque.
That is great to hear! Zoom zoom!Car runs great, I can't believe how quite the engine is, new plugs. Belt, rad cap and timing kit and it's back on the road.
Thank you everyone for all the help.
When's the last time you did the thermostat?
