the_desperado
- Mazda 2011 CX9
Hi
I have a 2011 CX9. lately I noticed that the brake pedal became very hard and I am hearing a hissing sound like air leakage when I depress it. I searched on the internet and found that these are the symptomes of bad brake booster. I even found a program from Mazda called SSP93 talking about the issue and listing the affected VINs and my car is one of them. I have scheduled an appointment with the dealer to get the booster replaced.
however I have noticed another symptom, when on stop light or anytime I press the brakes hard for around 1 minute the car stalls and the oil indicator appears. do you think it is the same booster issue? can the booster leak the air to a level that the engine is dead?
two days ago I tested this again and after two stalls I got a check engine light. I used my phone and OBD adapter to check the error and I can see the following two related to O2 sensors
P2195
P2197
so questions:
- do I have a bad booster issue?
-does this issue cause the engine to stall?
-is the oxygen sensor check engine error related to this is a well?
P2195
P2197
so questions:
