CorkSport.com is MAZDA PERFORMANCE!
Page 5 of 12 FirstFirst ... 34567 ... LastLast
Results 61 to 75 of 170
Thread: LankyKiwi's Rally-flavored SP20
  1. #61
    Registered Member
    2001 Mazda SP20 323
    Join Date
    May 2017
    Location
    Hamilton, NZ
    Posts
    150
    Thanks guys, it seems like the way forward is to keep the stock swaybar and leave the aftermarket one for wall decoration. For the price I paid ($35) I'm not too worried if it doesn't get used
    It was a mongrel to get out, even with the engine and shocks out of the way, getting it in will be another big job and not something I'm too keen to do just yet.
    Current plan is to redo the bushes, boots and bump stops on the shocks and arms, install those and see how they go
  2. #62
    Registered Member
    2001 Mazda SP20 323
    Join Date
    May 2017
    Location
    Hamilton, NZ
    Posts
    150
    Things you can fit in the back of a Mazda hatchback: (Not all at the same time )
    - 5 x road bikes and one on the towbar
    - 6x 54L bins full of parts and 4x 17 inch wheels
    - 8x 2+M lengths of wood, steel and other miscellaneous materials
    Moving house and garage means that the back of the Mazda has been working hard! It also means that I've had no time for doing anything major to the car
    I have, however, chased a few more clunks and rattles away, fixed a broken exhaust flange and welded in a flexy joint, and it's getting an oil/filter and spark plug change this week.
    I also took the Tokicos apart and it looks like all 4 are blown, none of the shocks rebound when compressed by hand Still, the springs are good and they'll go on sooner or later....
  3. #63
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,420
    Quote Originally Posted by LankyKiwi View Post
    Or 13 bundles of shingles.
    The Diagram Dude
  4. #64
    Comp Engineering Student Riot_Polizei's Avatar
    2002 Mazda Protege5
    Join Date
    Jan 2018
    Location
    Colorado
    Posts
    547
    Quote Originally Posted by pcb View Post
    Hella flush!!
    2002 Mazda Protege5
    ■ Sunburst Yellow ■ Black Rear Valence ■ Injen Cold Air Intake ■ Racing Beat Catback Exhaust ■ Moog Front Endlinks
    ■ Megan Racing Rear Strut Tower Bar ■ Racing Beat Rear Sway Bar ■ Mazda6 Front Big Brakes ■ Foglight Deletes
    ■ OBX 4-1 Headers ■ MP3 ECU ■ VTCS-less Intake Manifold ■ Mishimoto Aluminum Racing Radiator + Fan Shroud
    ■ AWR Trailing Arms ■ Eibach Lowering Springs
    ______________________________
  5. #65
    Registered Member
    2001 Mazda SP20 323
    Join Date
    May 2017
    Location
    Hamilton, NZ
    Posts
    150
    (Nearly) Instant lowering kit!
  6. #66
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,420
    Yea but I ended up wrecking my bearings.
    I should have done two trips.
  7. #67
    crazy tire guy tireboy's Avatar
    91 323 dx
    Join Date
    Feb 2008
    Location
    williams lake b.c.
    Posts
    70
    Opps....
  8. #68
    Registered Member
    2001 Mazda SP20 323
    Join Date
    May 2017
    Location
    Hamilton, NZ
    Posts
    150
    Thankfully no bearing blowouts this weekend, everything moved without a hitch.
    However, the new place has a steep driveway to park the car on and the handbrake isn't quite cutting it
    How do we adjust handbrake strength on a protégé?
    Still need to do a service and find a rear suspension clunk/Squeak
  9. #69
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,420
    There's an adjustment nut under the P-brake lever.
    Remove the plastic shroud around the handle to access it.
    My cables were so old, stretched and rusted that the adjustment nut was turned all the way and still no adequate braking.
    The cables were binding too leaving little pressure at the back.
    New cables fixed it.
  10. #70
    Registered Member
    2001 Mazda SP20 323
    Join Date
    May 2017
    Location
    Hamilton, NZ
    Posts
    150
    Thanks PCB, much appreciated.
    I've a funny feeling that the adjuster is all the way in, might be time for new cables, if I can find a supplier
  11. #71
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,420
    Rockauto has them.
    There's a third center piece as well.
    I reused mine, it was still working.
    I don't know how much shipping would cost for you or how your dollar compares but you can get a full price quote before you buy.
  12. #72
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,420
    Does your SP 20 have disc brakes ??
    The cables for drum brakes are different. They have different lugs on the end of the cable.
  13. #73
    Registered Member
    BJII Astina SP20
    Join Date
    Apr 2016
    Location
    Australia
    Posts
    225
    There's also the parking brake pad adjustment screw on the calipers too isn't there? I would think the caliper adjustment would be done with the in cabin adjustment somewhere in the middle position to allow fine tuning from the cabin?
  14. #74
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,420
    Quote Originally Posted by JazzySP20 View Post
    Yes, but if your rear calipers are working properly they should self adjust.
    The P-brake cable attaches to the operating lever that rotates every time you pull the P-brake handle.
    That rotation is what slowly adjusts the internal adjustment screw one notch at a time to keep your brake pedal at the proper height.
    If LankyKiwi can still get his P-brakes to do something then his calipers are probably working OK.
    In my case, the cables were binding so bad that the little return spring didn't have enough force to rotate the operating lever back after I released the P-brake handle.
    Then that caliper wouldn't release, then, as the pads wore down my foot pedal height started to change and the P-brakes stopped working.
    I Jerry rigged another spring on the attachment point to pull on the cable harder to keep it moving and self adjusting.
    Another thing LankyKiwi could do is, get in your car and push the brake pedal hard and hold it then operate the hand brake lever 40-50 times.
    This will make sure your rear calipers are fully adjusted and it might be enough to hold the car on your hill.
  15. #75
    Registered Member
    2001 Mazda SP20 323
    Join Date
    May 2017
    Location
    Hamilton, NZ
    Posts
    150
    Thanks guys, especially PCB- Legend!
    Mine has disks on the rear, I'll get it up on stands on the weekend and have a poke around, hopefully I'll get a bit more out of the cables
Similar Threads
  1. Replies: 0
    Last Post: 04-19-2012, 12:23 AM
  2. Rally MazdaSpeed3 wins class in New England Forest Rally
    By MS Pro Codriver in forum Pics & Builds
    Last Post: 07-30-2010, 02:29 AM
  3. Flavored Condoms (SFW)
    By aMaff in forum Pics & Builds
    Last Post: 02-05-2006, 04:26 AM
  4. Replies: 2
    Last Post: 02-14-2005, 09:57 AM
  5. MMM!!!!! Taco flavored kisses...
    By GI- in forum Lounge
    Last Post: 10-11-2004, 12:25 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
