CorkSport.com is MAZDA PERFORMANCE!
Results 1 to 6 of 6
Thread: Side step removal
  1. #1
    Registered Member
    Protege 5
    Join Date
    Sep 2017
    Location
    Seattle
    Posts
    1
    Side step removal
    I'm working on fixing some rusted areas around the wheel wells and I need to take off the side steps on my P5, I've looked online for the factory manual and I see there are a series of clips to take off first, has anyone seen how to do this online? Is there a special tool I need to use?
  2. #2
    Registered Member
    protege5
    Join Date
    May 2016
    Location
    GA
    Posts
    239
    you may want to elaborate on what you mean by a side step. or attach a picture, when i hear side step i think running boards on trucks and SUV's.
  3. #3
    Swollen Member Natey's Avatar
    Donated: $20
    Mazda
    Join Date
    Jan 2003
    Location
    Pleasure Point, California
    Posts
    6,388
    P5s come with side skirts. I think that's what he means.
    Sorry I've never had a reason to pop em off, but I'll bet if you get under the car it'll be pretty self explanatory. They're probably glued on too.
    NPOT (Norcal Protege Options Team)
    http://www.cardomain.com/ride/335883...photo-gallery/
  4. #4
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,945
    Yea... They call it a side step.
    I've had mine off before and ended up breaking a few before I figured them out. They're kinda brittle and hard to deal with.
    It's been a bunch of years and I forget if they sort a hook in or clip in or what.
    Count the number of A and B clips and where they're located as you go.
    I ended up putting a few little screws in to put it back on.
    I had a big rust hole through the body on both sides hiding under the side steps.
    The Diagram Dude
  5. #5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,945
    Quote Originally Posted by Natey View Post
    ...They're probably glued on too.
    They're not glued,... Just the annoying clips.
  6. #6
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,945
    I stared at the diagram then went to check my car.
    You remove the fastener and the B clips then the whole molding slides towards the front of the car and all the A clips disengage.
    All the A clips are hidden under the molding and you don't deal with them directly
    Don't try to move the molding up or down... Just straight towards the front.. The rear of the molding might catch and you'll have to pull it out of the way a bit.
Similar Threads
  1. Replies: 4
    Last Post: 01-07-2015, 02:43 PM
  2. How-to: Rear subframe/suspension removal step by step
    By smc0922 in forum Mazda6 How-To
    Last Post: 09-19-2010, 10:33 AM
  3. rear bumper step plate removal
    By korative3 in forum Mazda3 Lounge
    Last Post: 05-04-2009, 06:56 PM
  4. Removing Side Step Moulding
    By Bear600rr in forum Protege5
    Last Post: 04-17-2009, 11:53 AM
  5. Scratch Removal Step by Step?
    By vinnie mack in forum Mazda How-To
    Last Post: 11-26-2006, 01:53 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
