Compare auto reliability with reliable results at TrueDelta.com!
Results 1 to 3 of 3
Thread: P5 AXR Clunk Fix Possible?
  1. #1
    Registered Member
    03 Mazda Protege5
    Join Date
    Jul 2009
    Location
    SF, CA
    Posts
    16
    Smile P5 AXR Clunk Fix Possible?
    I have tried researching, but either found conflicting or partial info (or just didnít find the right thread) for my specific situation.
    Iím installing Tokico blues on my '03 P5, and was going to take the opportunity to install the racing beat swaybar and AXR clunk fix brackets I bought used a while back.
    Is this advisable/possible?
    A couple of threads mention that the brackets wonít fit the P5, but Iím not sure if that means with the OEM swaybar, and my rb swaybar would be fine.
    Also, the end links included in the clunk fix I bought are shorter than the endlinks I got off the MSP donor. Iím not sure if shorter is in order with the clunk, or if the msp endlinks are fine.
    All help greatly appreciated.
  2. #2
    Registered Member o.g.sk8er's Avatar
    Join Date
    Jul 2002
    Location
    los angeles, ca
    Posts
    1,540
    I had a set of those AXR brackets and regret selling it years ago.
    Yes they will work just fine. The only difference between the MSP and P5 subframes is where the sway bar bushings attach. The MSP has a reinforced tab to accommodate the larger 20mm RB sway bar. The P5 doesn't. This is the bracket those posts are about. Since your sway bar pick up points are now relocated, you need not worry about that anymore.
    As far as the end links, pretty sure you will use the shorter ones.
    If you ever change your mind and decide to sell those brackets, I got first dibs. Seriously.
    Good luck!
  3. #3
    Registered Member
    03 Mazda Protege5
    Join Date
    Jul 2009
    Location
    SF, CA
    Posts
    16
    Awesome!! Thanks for that; exactly what I was looking for.
    I'll honor your dibs, if I do ever part with them.
    Appreciate it.
Similar Threads
  1. Installed Clunk fix and clunk still exists?
    By zuku26 in forum Mazdaspeed Protege
    Last Post: 03-18-2010, 01:13 AM
  2. Replies: 24
    Last Post: 05-10-2007, 06:31 AM
  3. Replies: 6
    Last Post: 10-21-2003, 08:53 AM
  4. Clunk?
    By brennan in forum Mazdaspeed Protege
    Last Post: 04-22-2003, 05:35 PM
  5. Clunk diddy clunk clunk
    By brain in forum Protege5
    Last Post: 10-10-2002, 07:41 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
