Page 4 of 5 FirstFirst ... 2345 LastLast
Results 46 to 60 of 64
Thread: Maintenance Mode for 2016/2017 CX-5 electronic brakes
  1. #46
    Registered Member
    Join Date
    Jun 2019
    Posts
    2
    My CX-5 is a 2016 and the TSB does apply. I am going to call the dealership tomorrow to see if they will update the rear calipers, but the car is out of warranty with 75k mi on it.
    Quote Originally Posted by yrwei52 View Post
    It's unfortunate that many DIYers don't aware the rear brake pad replacement procedure is different between the one with Electrical Parking Brake and without. Just like in earlier days some didn't aware the rear disk brake can't just push the piston in like the front, but also have to turn it.
    In your situation IMO you should have no problem to use the foot brake, but the EPB won't be functioning which of course is not a safe-driving situation. And if nothing unusual happens and there's no leak from the real calipers, the piston seal should be fine. But if you have a 2016 CX-5, you may also want to consider getting newer version of the rear brake calipers as the original calipers are having dragging issues based on Mazda's TSB.
    I wonder how difficult or how costly to replace the broken EPB wire connector ...
  2. #47
    Registered Member Kaps's Avatar
    Donated: $15
    CX-5 Touring 2016.5
    Join Date
    Aug 2016
    Location
    Lewisville North Dallas Suburb
    Posts
    2,200
    Here are US VIN ranges:
    US (2016 MY) MEXICO (2016 2017 MY) JM3 KE **** ** 600015 - 866136
    Mine is under the 866136 VIN range. I am going to be doing a test on this. I am out of warranty in August end.
    Official Defender of Zamdatm
  3. #48
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    8,093
    Arrow Maintenance Mode for 2016/2017 CX-5 electronic brakes
    Quote Originally Posted by Kaps View Post
    You have 2016.5 and your CX-5 is in the TSB VIN range? When is your manufacture date?
    If I were you, I'd go to Town North Mazda as they're fully aware of the TSB, and they're more willing to replace rear calipers if they see any sign of uneven wear on disk pads, especially if you can talk to their master mechanic.
  4. #49
    Donated: $15
    CX-5 Touring 2016.5
    Join Date
    Aug 2016
    Location
    Posts
    2,200
    I see no symptoms. No dragging or noise. My rotors look ok. Can't hesr any noise. I will still get it checked at my dealer. Hope the at least inspect fully.
  5. #50
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    8,093
    In my case at 25K miles right before 3 years my rear brakes were having no dragging or noise symptom too. But I went ahead to have service advisor checking the rear brakes for one of 10 final warranty checkups and fixes. The first round the tech who was doing all the work stated there's nothing wrong on rear brakes. Unlucky for the tech he screwed up 2 easy fixes and I used that as a reason to have the master mechanic to double check rear brakes as I really don't want the potential EPB problem after warranty ran out. The master mechanic checked rear brakes again and found different thickness on inner and outer disk pads on both sides, and went ahead performed the TSB under warranty.
    What I'm trying to say is you may not have any symptoms, but dealer's attitude will make big difference whether or not you can get revised rear calipers to avoid later EPB problem.
  6. #51
    Donated: $15
    CX-5 Touring 2016.5
    Join Date
    Aug 2016
    Location
    Posts
    2,200
    Ok. I will give it a shot. My dealer does not do warranty work on Saturdays. So it has to be weekdays yikes.
  7. #52
    Donated: $15
    CX-5 Touring 2016.5
    Join Date
    Aug 2016
    Location
    Posts
    2,200
    That got me thinking is there a list of TSBs that I should focus on for a 16.5 CX5? Something I am not aware of but might get smacked later??
  8. #53
    Donated: $15
    CX-5 Touring 2016.5
    Join Date
    Aug 2016
    Location
    Posts
    2,200
    yrwei - if you can blank out personal info and show me the invoice or paperwork for Town North maybe I have a better chance that my dealer would entertain it. I know you are in Cali now - it would be great if its possible.
  9. #54
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    8,093
    PM sent.
  10. #55
    Registered Member
    Join Date
    Aug 2019
    Posts
    4
    Great post. Is this the same for 2018 CX-5?
  11. #56
    Registered Member
    Join Date
    Sep 2019
    Posts
    1
    I dodged a bullet for sure. I unplugged the electric parking brake. Then replaced the rear pads as normal, turning the caliper back into position. I could hear the motor turning on the ebrake too. When I put it all back together, including plugging the e-brake back in, and went for a ride. The parking dash light was on. The parking switch was flashing and the brake light on the dash was flashing too! I started reading this thread and figured I was screwed. Well, I put the car into maintenance mode and then back out of maintenance mode and it works!! whew...
  12. #57
    Registered Member erhayes's Avatar
    Donated: $10
    Mazda CX-5 FWD Touring
    Join Date
    Jan 2007
    Location
    Cape Coral, FL.
    Posts
    2,892
    This is what we need to do to change rear brake pads and, this is called progress? What a crock of stuff. Ed
  13. #58
    Registered Member CX-5um's Avatar
    13' CX-5 and 16' Mazda6 both Touring w/Tech/Bose
    Join Date
    Jul 2012
    Location
    Glendale, AZ
    Posts
    3,258
    Wait so Maintenance mode = push piston back and not turn it? this makes it easier if so.
  14. #59
    Registered Member
    Mazda CX5 Signature
    Join Date
    Sep 2019
    Location
    Phoenix
    Posts
    1
    Excellent instructions. I watched a youtube on this and it was confusing. I prefer written instructions for the complicated steps like '3 times' etc. Thank you.
  15. #60
    Registered Member
    2016.5 CX-5 GT
    Join Date
    Sep 2016
    Location
    NA
    Posts
    268
    Quote Originally Posted by CX-5um View Post
    Sort of... When first engaging Maintenance Mode, it backs off the parking brake motor but not the piston... You have to push the piston back manually if you're replacing the pads since the new pads will be thicker than the worn pads.. After you're done replacing the pads, you have to make sure the piston grooves line up with the pin on the back of the brake pad...then you turn off maintenance mode and the motor will automatically push the piston back out until it engages the pad and senses a certain pressure it will automatically stop.
Similar Threads
  1. Replies: 5
    Last Post: 10-04-2017, 12:04 AM
  2. 2017 cx-5 sport mode
    By Panda_415 in forum CX-5 General
    Last Post: 08-18-2017, 07:16 PM
  3. 2017 Sport Mode - Stuck in 1st gear
    By SweetPete in forum CX-5 General
    Last Post: 07-26-2017, 03:35 PM
  4. Replies: 1
    Last Post: 06-30-2017, 11:56 AM
  5. Replies: 33
    Last Post: 03-21-2017, 04:14 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
