Is there a way to adjust the time for the parking screen to be shown on the info screen? It takes at least 30sec for the display to switch to my default screen.
Sorry, except when reversing, the screen will give priority to the reverse camera, then after putting the shifter to Drive, it will show the parking sensor screen (the one with the top view of the car which shows which corner of the car is near an object) for more than 30sec before switching to whatever screen I was on before that.
I assume you have front parking sensors. If so, just press the button to turn the sensors off. The screen will return to normal. No need to wait 30 seconds.Sorry, except when reversing, the screen will give priority to the reverse camera, then after putting the shifter to Drive, it will show the parking sensor screen (the one with the top view of the car which shows which corner of the car is near an object) for more than 30sec before switching to whatever screen I was on before that.
When you put it in reverse and then put it into drive it'll come back on againM
Yes that's what I do, and I will forget to turn it back on if I'll need it.
Then press the button to turn it off. Just remember to press it again to turn it on just before you parkI doesn't. When I'm in drive and turn it on, it will stay on that screen for more than 30sec
So there's no way to shorten the time for it to show on the infotainment screen? I am hoping there's a setting somewhere to switch it out when I engage drive.
This is correct function...
From reverse to park the car will stay in reverse sensor screen
It will go away if you press the Parking sensor button on the switch assembly above your knee.
That's quite bothersome. I hope there's going to be a software upgrade that will make the reverse screen stay for only around 5 sec after engaging drive from reverse.
Just found out that the parking sensor screen will go away when the car is driven above 10km/hr. I have to read the manual to notice this.
