Mazda 323F 1996 1.8 electric problem
maoram9
mazda 323f
so i have Mazda 323F 1996 engine 1.8 manual.
i drive the car and the engine make sound of choke and cutting of.
i replaced the fuel pump the mad sensor and the air intake hose.
i go to the mechanic and he say my engine is looks ok and its an electricity problem.
what should i check spark plugs ? ignition wires ? distributor ?
my freind says my Exhaust system is bad...
Have you tried pulling any trouble codes? Check your filter, look for vacuum leaks, check your spark plugs, spark plug wires, ignition coils, make sure all the sensors under the hood are connected and that wires aren't cut or torn.
no i havent try to pulling codes.
i replaced the fuel filter he was blocked
i dont have coils i have distributor and spark plugs and iridium plugs.
the guy who build this project car say i need to check the Vacuum pipes
is the throttle can be a problem ? when i press the gas it respond but sometimes it dosent
You need to scan your car for codes if you want any help.
If your exhaust system has a leak and is loud, you can get someone to just weld the leaks.
I gotta agree on checking the codes first as this will give you an idea of where to start looking. Vacuum lines can be an issue with a car that old. It would probably be best if you replace all the vacuum hoses unless you know for sure that they've been replaced recently.
