Made in USA and Free Shipping on all orders shipped inside the US.
Results 1 to 11 of 11
Thread: Flooded passenger side mats/floors
  1. #1
    Registered Member
    mazda, protege 5, 2003
    Join Date
    Aug 2017
    Location
    houston, tx
    Posts
    3
    Question Flooded passenger side mats/floors
    Hi,
    I'm trying to figure out why/how the passenger side of my car ('03 Protege 5- 5 door no sunroof, manual) keeps on flooding with water when it rains. I've done a few google searches and have some ideas, but nothing specific for a protege 5. It's only the passenger side floors that flood and so far tends to happen after it rains. When I look under the hood and try to remove the wiper cowl, I can't track the water anywhere (like on the videos I find through my google search). Everything under the hood is completely dry. I'm 90% sure the liquid is water as it doesn't smell like anything in particular, has a residue, and all my fluid levels are topped off and are remaining steady. The water is accumulating between the metal flooring of the car and the carpet that overlies it.
    Anyone have any ideas on how to trouble shoot/fix? THX!
  2. #2
    Registered Member Ilikebikes's Avatar
    06 Mazda 3 Hatchback GT
    Join Date
    Jul 2015
    Location
    Northern California
    Posts
    166
    This might be a bit crazy, but your profile says Houston....exactly how much rain has your car taken on lately?
  3. #3
    Registered Member
    protege5
    Join Date
    May 2016
    Location
    GA
    Posts
    373
    i'd check your AC drain tube. Other than that maybe door seals, or something else. remove as much of the interior trim as you can (glove box, A pillar, dash if possible) and have someone start hitting it heavy with a garden hose until you can see water coming in.
    or it may not be from the rain at all, and your AC drain tube from the evap box is either dislodged and draining into your floorboard instead of outside the car, or the evap box is clogged with debris and leaking on to your floor.
  4. #4
    Registered Member
    Join Date
    Aug 2017
    Location
    houston, tx
    Posts
    3
    Hurricane harvey
    Quote Originally Posted by Ilikebikes View Post
    Hurricane Harvey just hit over the last 4 days... we had a LOT of rain.
  5. #5
    Registered Member
    Join Date
    Aug 2017
    Location
    houston, tx
    Posts
    3
    All good thoughts, I'll check into all of them. Thank you! Now I just need to find a shop or friend who can help me do all of that. Door seals are good, I checked that first when trying to track the leak source from the inside of the car.
  6. #6
    Is it a Mazda or a Subaru KrayzieFox's Avatar
    01 MP3 Turbo
    Join Date
    Apr 2005
    Location
    Eugene, OR
    Posts
    3,617
    It might be a known body seam issue. I just dealt with this myself, had to remove the dash and heater blower unit to patch it up, huge pain in the ass.
    https://www.mazdas247.com/forum/show...ter-leak/page2
  7. #7
    Registered Member Derty_rabbit's Avatar
    2002 Protege5
    Join Date
    Jan 2017
    Location
    Austin Texas
    Posts
    92
    Have u checked ac box??? Also look for body plugs or grommets that may be busted and allowing water in
  8. #8
    Registered Member
    Mazda Protege 5 (2003)
    Join Date
    Jul 2012
    Location
    Puerto Rico
    Posts
    76
    Quote Originally Posted by justaperson05 View Post
    As others have mentioned check the A/C drain hose. Hurricane flooding brings debris and mud and this tends to clog this hose. I can ascertain from experience
  9. #9
    ......................... i12drivemyMP5's Avatar
    Donated: $5
    323F
    Join Date
    Apr 2005
    Location
    Posts
    7,584
    Mine never left the garage at my 130' elevation house during that shit. I have a truck for that. Yep on body seam, door seals, AC drain or dry rotted grommets but I will add........crispy windshield seal possibly? If you didn't drive thru any high water then the list gets smaller.............
  10. #10
    I LIKE RICE !!! gnut's Avatar
    Mazda Protoge 5
    Join Date
    Feb 2011
    Location
    South Alabama
    Posts
    33
    Getting moisture in my floorboard as well lately when running the AC for a while. Not as much moisture as "justaperson05" shows in his pic, but a little moisture. I had the car on jackstands the other day and couldn't find a condensation drain line anywhere on the passenger side. Any thoughts on where it might be? I'm probably overlooking it.
  11. #11
    Donated: $5
    323F
    Join Date
    Apr 2005
    Location
    Posts
    7,584
    Trace it from inside the car in passenger footwell. It is where the tube could have been kicked off the box and condensation just dripping into floor instead of going out.
Similar Threads
  1. New OEM side engine mount (passenger side) no threads in the top bracket hole
    By Pootie Tang in forum CX-9 Engine & Transmission
    Last Post: 11-13-2016, 03:17 PM
  2. Replies: 4
    Last Post: 09-20-2014, 12:36 AM
  3. Wet right side floors
    By low rider luis in forum Mazda Protege
    Last Post: 11-11-2013, 11:53 PM
  4. FS: Mazda5 Side Sill Extension - Carbon Gray - Passenger Side Only
    By a10thunder in forum Completed Transactions
    Last Post: 08-04-2010, 10:28 PM
  5. WTB MSP Passenger Side Bumper Grill. Driver Side A Pillar Cover.
    By Artur1976 in forum Completed Transactions
    Last Post: 11-18-2009, 09:08 PM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
