In Memory of Member 1338
Results 1 to 14 of 14
Thread: Protege5 rough idle
  1. #1
    Registered Member
    Mazda, Protege5
    Join Date
    Aug 2017
    Location
    Alexandria VA
    Posts
    13
    Protege5 rough idle
    Hello everyone. I can't seem to find out the cause of my rough idle. I did use the search function however I can't seem to fix my issue.
    My 03' Protege5 has about 130,000 miles and I have changed/cleaned the following to try to fix my bad idle..
    *Spark Plugs
    *Coils
    *Coil wires/Plugs
    *Battery
    *Battery Terminals
    *Cleaned EGR
    *Reset ECU
    *Fuel Injector Cleaner
    *Cleaned MAF
    The car when cold will start up and have high revs and will drop down to about 200-300 rpm and then shoot up to 1k-700 RPM
    Thank you for the help. Sorry for Garbage formatting.
  2. #2
    2008.5 MGM MS3 rsvinylgraphics's Avatar
    Donated: $5
    Join Date
    Oct 2009
    Location
    Indiana
    Posts
    1,137
    Don't see cleaned MAFS on your list, maybe try that.
  3. #3
    Registered Member
    Mazda, Protege5
    Join Date
    Aug 2017
    Location
    Alexandria VA
    Posts
    13
    Sorry I did clean the MAF. No luck
  4. #4
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,860
    Clean your IAC valve...
    Seafoam in your gas and up the brake booster vacuum line...
    The Diagram Dude
  5. #5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,860
    If you reset your ECU, it needs to relearn how to idle the car... Takes about 100 miles with lots of idling at different temperatures and other conditions...
  6. #6
    Registered Member
    Mazda, Protege5
    Join Date
    Aug 2017
    Location
    Alexandria VA
    Posts
    13
    Thanks ill go do that and get back to you and see how it does! Thanks again!
  7. #7
    Registered Member
    Mazda, Protege5
    Join Date
    Aug 2017
    Location
    Alexandria VA
    Posts
    13
    Question. How do I "up the brake booster"
  8. #8
    Certified Mazda Tech hornsfan10609's Avatar
    2003.5 Mazdaspeed Protege x2
    Join Date
    Jun 2009
    Location
    Austin, Tx
    Posts
    8,125
    He means putting seafoam into the motor through the vacuum line for the intake manifold. This should not be necessary to resolve your erratic idle. Are there any CELs? I would suspect incorrect plug gap, dirty IAC or failing MAF sensor.
    Mod List. "Jinba Ittai"
    2003.5 Titanium Mazdaspeed Protege #1345 Purchased 7/20/10
    2003.5 Titanium Mazdaspeed Protege #1574 Purchased 10/25/14-SOLD
    2003.5 Titanium Mazdaspeed Protege #32 Purchased 3/23/19
    2003.5 Laser Blue Protege5 Purchased 6/17/17 SOLD
    2009 Highland Green Mustang Bullitt #5998 12.9@110
    2002 Red Protege5 RIP:4/25/10
  9. #9
    Registered Member
    Mazda, Protege5
    Join Date
    Aug 2017
    Location
    Alexandria VA
    Posts
    13
    Brand new maf. No CEL. Plugs I gapped correctly. IAC I cleaned. It seems to be better but not 100%
  10. #10
    Registered Member
    02 Mazda Protege5
    Join Date
    May 2018
    Location
    Danville, VA
    Posts
    3
    I am having the exact same issue DayMan. Did you ever get it figured out? I swapped MAF sensors, installed new plugs, wires and IAC valve. I would like to know more about the idle relearn steps if anyone could help me with that, please help. My car has a manual trans also. What is the correct gap measurement on the plugs hornsfan10609?
  11. #11
    Registered Member
    02 Mazda Protege5
    Join Date
    May 2018
    Location
    Danville, VA
    Posts
    3
    Also how do I reset the ECU? These may be simple questions but I have limited automotive experience.
  12. #12
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,860
    Quote Originally Posted by Myers View Post
    Also how do I reset the ECU? ...
    Disconnect the negative battery cable, wait ten minutes, then reconnect it.
  13. #13
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,860
    ... I would like to know more about the idle relearn steps if anyone could help me with that, please help...
    You just kinda wait for the car to do it's thing.
    However, if you give it lots of chances to bring your car to idle, it will happen faster.
    You could keep hitting the clutch and let it idle while you're coasting.
    My car almost stalls while it's relearning, some cars do stall. Keep that in mind while you're driving.
    ... What is the correct gap measurement on the plug?
  14. #14
    Registered Member
    02 Mazda Protege5
    Join Date
    May 2018
    Location
    Danville, VA
    Posts
    3
    Thanks PCB, I definitely try these out.
Similar Threads
  1. Replies: 2
    Last Post: 01-07-2016, 12:30 AM
  2. 2003 Protege5 Rough Idle When A/C Is On
    By 1PaulSilva in forum Mazda Protege
    Last Post: 08-28-2015, 10:46 PM
  3. Replies: 7
    Last Post: 05-11-2011, 09:32 AM
  4. Replies: 5
    Last Post: 03-03-2009, 08:44 AM
  5. Protege5 rough idle / stalling
    By spartan_mazda5 in forum Protege5
    Last Post: 11-13-2007, 07:07 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
