Its certainly the same. My MKV Rabbit had a similar system that I'm pretty sure was also Continental. I don't think there is any reason to reinvent the wheel.
It became mandatory is the US in 2008. Pretty sure it's mandatory in Europe as well.
But if Mazda had decided to go more expensive route on TPMS system, why couldn't they give us direct-read tire pressure display TPMS like Nissan Rogue?I do also prefer direct sensors vs the abs inferred method.
You do replace valve stems each time you get a new set of tires. The pressure sensor and valve stem are one unit and you have to wonder if you want to replace pressure sensor valve stem unit for the next 60K~80K miles of tire service.
The last time I bought tires, Discount Tire rebuilt the pressure sensors ($7.00 each).
The parts they are "rebuilding" are for making a seal between the valve assembly and the wheel, and preventing leak. The pressure reading and transmitting portion (the expensive part) have sealed battery, limited lifespan, and are disposable and if they are replacing that part, it is probably in the $40-$100 range per wheel.
They also replaced the spring loaded 'valve' that screws into the assembly (Schrader?).
With my CX-5 I swapped the wheels myself and didnt have to do anything other than drive the car to reset the sensors.
Okay, I'm about to replace the factory 19" GT wheels on my 18 CX-5 with some used aftermarket wheels, so I've been looking into the TPMS. I don't have it on my winter tires.
Now it makes some sense what Mazda has done. The 17 and 18 models use TPMS sensors in the wheel instead of ABS. Aside from cost, from a customer's perspective, this implementation is the most simple. It just works. With the ABS system one needs to reset anytime something is done to the tires. With the TPMS system, the customer doesn't need to do anything, other than investigate which tire is low when the light comes on.
I think the reason we don't get a discrete display for each tire, is that the Mazda system doesn't know which sensor is where, it just looks for 4 sensors that are happy. In that state, no light, any other state, light. Its dead simple. If the tires have a compatible TPMS sensor, no programming is required. The car finds them on its own.
In all my years of driving, never encountered a blow out.
Because of my proactive checking, I have picked up slow leaks both visually and when getting pressures checked.
If it is such a crucial piece of technology, it would have been mandatory part of all vehicles by now.
Maybe I am lucky but I also notice visually when a tyre doesn't seem right. Always catches my eye. Picked up almost half a dozen slow leaks on different vehicles over the years.You have simply been very lucky.
My son with the Mazda3 recently arrived at our house on the back of a transporter, TPMS gave him a early warning saving a blow out at 70mph plus with his family on board, unfortunately the sealant supplied failed to hold the leak under any pressure over 20psi. So he had to be recovered a 2 hour trip took over 4 hours.
He now has a spare space saver.
