CorkSport.com is MAZDA PERFORMANCE!
Results 1 to 8 of 8
Thread: Turbo Specialties (TSI) turbo kit for an 02 Protege5
  1. #1
    Registered Member
    2002 Mazda Protege5
    Join Date
    Jul 2017
    Location
    VA
    Posts
    15
    Hey guys,
    I am having problems finding information on this kit. I am picking up a Protege5 soon and it is coming with a Turbo Specialties (TSI) turbo kit. I am reading the installation instructions, and you have to add on an additional fuel computer to control two remote mounted injectors. What I am wondering is can I just install a set of MSP injectors and get an MSP ecu and be done with it? Essentially use the hardware that comes with the TSI kit (turbo, manifold, lines, intercooler and piping) and just install the MSP injectors and ecu, and not use the additional injectors with the add on computer? If I can do this does anyone know if the P5 and MSP run the same base fuel pressure? What about fuel pump output? I'm guessing the MSP has a beefier fuel pump. Thanks for any information.
    Here is a link to the kit, the one I am getting is used and comes with the additional injectors and the fuel control stuff.
    http://www.turbospecialties-race.com...ocgi3mce8vkte3
  2. #2
    31N007 KingOfSpades007's Avatar
    Mazda Protegé5
    Join Date
    Dec 2011
    Location
    Canton, MI
    Posts
    686
    in theory yes, MSP ECU should be all you need to run the car safely. The fuel pump and pressure, IIRC, is the same between the NA and turbo motors. As are the injectors.
    The plugs at the ECU are the same, but the MSP always had ABS, so you'll just have an ABS code if the P5 is non-ABS, and you'll just have to pull the bulb in the cluster.
    An SSAFC is really wise to have for anyone with an MSP or if going turbo, as it allows for a better fuelling map (stock is pig rich)
    Sent from my XT1575 using Tapatalk
    I need a brain.
    2002 Protege5
    Performance
    TWM SS
    CS shifter bushings
    Fidanza flywheel
    Eibach springs
    Tokico Illumina 5 way adj. struts
    AWR MM (all 4)
    RE71R on Filk FTDs
    Visual
    JDM tails
    Mini H1 7.0 35W 4500K
    1996 Subaru Impreza Outback
    Winter beater
    1993 Ford Escort GT
    "The Rally-X Pig"
    That cone looked rather tasty...
  3. #3
    Registered Member
    2002 Mazda Protege5
    Join Date
    Jul 2017
    Location
    VA
    Posts
    15
    Quote Originally Posted by KingOfSpades007 View Post
    I was just cross referencing part numbers and it does appear that the p5 and MSP can use the same fuel pump and injectors (at least according to rock auto). When I was googling this before I thought the p5 was rated some where around 280cc (don't remember what pressure they are tested at) and the MSP's were some where in the low 300's cc.
    I don't have the P5 yet so I don't know if it has ABS, even if it does not that is not a big deal to me.
    Good idea on the SAFC, I run one of those on one of my maximas and it does help out a ton with smoothing out the a/f ratio. What do most of the boosted guys shoot for? 12:1?
  4. #4
    Certified Mazda Tech hornsfan10609's Avatar
    2003.5 Mazdaspeed Protege x2
    Join Date
    Jul 2009
    Location
    Austin, Tx
    Posts
    8,111
    That is correct, the MSP has the same 280cc injectors, fuel rail, IM, fuel pump, fuel lines, FPR, etc as the P5 and other 01-03 FSDE Proteges.
    Typically in boost you are aiming for about 12:1, however with the primitive ECU in the Protege it may be safer to shoot slightly less, around 11.5:1.
    Mod List. "Jinba Ittai"
    2003.5 Titanium Mazdaspeed Protege #1345 Purchased 7/20/10
    2003.5 Titanium Mazdaspeed Protege #1574 Purchased 10/25/14
    2009 Highland Green Mustang Bullitt #5998 12.9@110
    2002 Red Protege5 RIP:4/25/10
  5. #5
    Registered Member
    2002 Mazda Protege5
    Join Date
    Jul 2017
    Location
    VA
    Posts
    15
    How much boost does the MSP run stock? I know the TSI kit comes set at 6 psi, I would like to run closer to 10 psi once the car is properly tuned. It seems like that is as high as people recommend going with out going into the engine.
  6. #6
    Join Date
    Jul 2009
    Location
    Austin, Tx
    Posts
    8,111
    The stock MSP runs between 6-7psi. Typically 10-11psi is the safe limit for a stock FSDE. The boost level you run will depend on the size of the turbo. ~10psi on a T25 MSP turbo is not the same as 10psi on a T30.
  7. #7
    Registered Member
    2002 Mazda Protege5
    Join Date
    Jul 2017
    Location
    VA
    Posts
    15
    Quote Originally Posted by hornsfan10609 View Post
    The turbo that comes with the kit is a t25
  8. #8
    Registered Member
    2002 Mazda Protege5
    Join Date
    Jul 2017
    Location
    VA
    Posts
    15
    At what point are the stock injectors maxed out at stock fuel pressure with a t25 turbo?
Similar Threads
  1. Turbo Kit by Turbo Specialties - SOLD
    By Tyrekikr in forum Completed Transactions
    Last Post: 02-23-2013, 08:45 AM
  2. Protege5 turbo
    By projectprotege5 in forum Mazdaspeed Protege
    Last Post: 12-27-2012, 04:55 AM
  3. FS Turbo Specialties Kit - $800
    By Tyrekikr in forum Mazda Protege
    Last Post: 05-26-2012, 09:37 PM
  4. Turbo Specialties Superior Turbo Kits
    By meinp5 in forum Mazda How-To
    Last Post: 03-13-2007, 08:24 PM
  5. 03 Protege5 Turbo help
    By johnwayne in forum Mazda How-To
    Last Post: 02-13-2007, 10:21 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
