It also has a red light to indicate if it's overheating.I have a 2012 CX5 import from Japan and no temp guage only a little blue light that shows when cold and goes out when warmed up is that the normal one cheers john
They have? That's a step in the right direction.Yes it is normal. The 2017 model has introduced a temperature gauge
If it is truly a gauge and not a light that turns on or off based on temp, that is an improvementI think it's digital, but still preferable over none at all.
Agreed. Nice to see little improvements like that.
That's perfect!Here's what it looks like. The car was just started so still reading cold.
Most vehicles now days don't have working temp gauges anyways, same for oil pressure. Just idiot-gauges that always hover in the middle. GM was always good about using real gauges on their cars though, and my 370Z had a real oil and coolant temp gauge. Ford loved their idiot gauges back in 2005 when I worked for them though.
With the built-in temp gauge on the 2017 CX-5, you are now free to monitor another parameter on your OBD2 gauge. The ScanGauge can display at most only 4 parameters, so this is a big help.There are a number of OBD2 based Temperature gauges available. I have a ScanGauge II setup to show Temperature and voltage.
I pull a trailer so I wanted to know the temperature.
Very nice. Thanks for confirming [emoji106] [emoji3]Here's what it looks like. The car was just started so still reading cold.
