Your Best Source for Genuine Mazda Parts!
Results 1 to 9 of 9
Thread: P0550 Code...Power steering pressure sensor..
  1. #1
    Registered Member
    '02 Mazda Protege5
    Join Date
    Apr 2017
    Location
    Mount Kisco NY
    Posts
    27
    Just when I fix one thing, something else goes wrong. lol. so far this week I fixed the noise which I thought was a bad alternator bearing but turned out to be a loose belt, got the fog lights to work, (someone had cut the wire to the relay for some reason) and I had a noisy blower motor which turned out to be a leaf in the turbine. now I have a "pending code" P0550 "power steering pressure switch"
    first of all, what's the difference between a "pending code" and a CEL? CEL currently not lit, and i'm still at 5/8 monitors ready since last doing work on the car (disconnected the battery)
    Seems easy enough, I assume that small single wire coming out of the PS pump is the sensor in question. Is there a way to test it with a voltmeter?
    although, it probably is bad, I noticed the idle kind of drops a bit when I'm stopped but I turn the wheel, like when parallel parking, even though it doesn't stall.
    when I unbolt the sensor, will I have to worry about pressurized PS fluid spewing out everywhere?
  2. #2
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,623
    Your particular code needs to show up for two consecutive drive cycles....
    When it happens the first time it is pending code... It needs to happen a second time to pop a code.
    You can test it...
    The Diagram Dude
  3. #3
    Registered Member
    '02 Mazda Protege5
    Join Date
    Apr 2017
    Location
    Mount Kisco NY
    Posts
    27
    I'm gonna test it out later when it's cooler. Would a PS switch sensor for a base protege work on the P5? on eBay the one listed for P5 is 140 dollars but the base protege is $24.99. They look identical. not sure why the price is so different.
  4. #4
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,623
    I say go for it.
    You don't even need the PS pressure switch...
    Just don't crank your steering wheel all the way... Back it off a quarter inch after max...
    ( it tells the ECU to crack up the idle.. Go gently while you're steering and you don't need to crank the idle.)
  5. #5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,623
    Quote Originally Posted by wrathofpaul View Post
    I.. on eBay the one listed for P5 is 140 dollars but the base protege is $24.99. They look identical...
    They may have a different pressure rating but I'm pretty sure it doesn't matter..
    I never like to kick my idle up... It means I'm cranking the steering wheel too hard..
  6. #6
    Registered Member
    '02 Mazda Protege5
    Join Date
    Apr 2017
    Location
    Mount Kisco NY
    Posts
    27
    Meh, drove around a bit and rechecked the code. code is gone. Guess I won't worry about it until I get a full blown CEL...
  7. #7
    Registered Member
    '02 Mazda Protege5
    Join Date
    Apr 2017
    Location
    Mount Kisco NY
    Posts
    27
    Update on the PS switch: I have noticed my car was misfiring slightly at idle, or at least that's what it sounded like. It would bounce within 50 rpm or so so not too bad but enough to be noticeable. and when I open the air box i hear it really well. I thought it was the wires plugs and coils so I changed all of that and eventually the sputtering came back.
    now here's the weird part. evidently the PS pressure switch on the Power steering pump is loose, like the part that sticks out where the wire clips on to. if i wiggle it, i hear the idle speed change slightly and then i hear the sputtering. so I'm assuming that's the issue causing the sputtering/misfire or whatever it is. which is weird because why would power steering pressure have anything to do with the ignition system and misfire. But maybe since everything is tied into the PCM. I ordered a new sensor so we'll see what happens.
  8. #8
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,623
    I'm guessing your bad switch has a bad connection and is telling the ECU to turn the idle up and down 10 times a second.
    You're probably not having a misfire...
    You would almost certainly have a code if you were. (P0300-P0304)
  9. #9
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,623
    You could probably just disconnect the switch...
    The ECU probably wouldn't know... You just wouldn't have your car idle up when the switch should kick in.
Similar Threads
  1. WTB: 2.0L Power Steering Pressure hose
    By Jperera in forum Want To Buy
    Last Post: 11-03-2014, 01:01 PM
  2. Power steering Pressure line question
    By JAZ32*PD* in forum Mazdaspeed6
    Last Post: 06-20-2012, 12:59 PM
  3. Replies: 3
    Last Post: 04-11-2012, 09:57 PM
  4. I NEED a power steering pump sensor!!
    By ELEmental59437 in forum Completed Transactions
    Last Post: 11-07-2008, 06:39 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
