Show your support and Donate!
Page 1 of 4 123 ... LastLast
Results 1 to 15 of 60
Thread: Dome lights wont come on when doors open?
  1. #1
    Registered Member
    Mazda protege5 99
    Join Date
    Sep 2016
    Location
    IL
    Posts
    33
    Are they even supposed to come on in a P5 1999?
    Sent from my SM-G950F using Tapatalk
  2. #2
    ......................... i12drivemyMP5's Avatar
    Donated: $5
    323F
    Join Date
    Apr 2005
    Location
    Posts
    7,396
    flip the switch to "door"
  3. #3
    Registered Member
    Mazda protege5 99
    Join Date
    Sep 2016
    Location
    IL
    Posts
    33
    Quote Originally Posted by i12drivemyMP5 View Post
    I dont have a switch, theres a button on and off
  4. #4
    Registered Member
    Mazda protege5 99
    Join Date
    Sep 2016
    Location
    IL
    Posts
    33
    I thought you meant the lights right under the two front seats, the middle light does indeed have doors but I dont have a bulb there.
    Should the front lights light up if I set it to door switch or is it only the middle one?
  5. #5
    Registered Member Derty_rabbit's Avatar
    2002 Protege5
    Join Date
    Jan 2017
    Location
    Austin Texas
    Posts
    92
    Check the micro switches on the door sill. Black little rubber nips
    SC:derty_rabbit IG: derty_rabbit add me up
  6. #6
    Registered Member
    Mazda protege5 99
    Join Date
    Sep 2016
    Location
    IL
    Posts
    33
    Quote Originally Posted by Derty_rabbit View Post
    What about them? They work ok I guess?
  7. #7
    2002 Protege5
    Join Date
    Jan 2017
    Location
    Austin Texas
    Posts
    92
    How do u know they work??? That's what sets the light on and off. And pics of ur dome light would help too
  8. #8
    2002 Protege5
    Join Date
    Jan 2017
    Location
    Austin Texas
    Posts
    92
    light in my p5
  9. #9
    Registered Member
    Mazda protege5 99
    Join Date
    Sep 2016
    Location
    IL
    Posts
    33
    Looks just like yours but I lack the bulb. Should the front light light up aswell?
  10. #10
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,381
    Quote Originally Posted by arcaneex View Post
    ... the middle light does indeed have doors but I dont have a bulb there.
    The middle light with the door switch is the only light that comes on when you open your door...
    Go get a new bulb for it.
    The Diagram Dude
  11. #11
    Registered Member
    Mazda protege5 99
    Join Date
    Sep 2016
    Location
    IL
    Posts
    33
    Quote Originally Posted by pcb View Post
    Gotcha, it is possible to rewire it so the front lights come on too? I got leds there and they light up the interior way better than the bulb.
  12. #12
    2002 Protege5
    Join Date
    Jan 2017
    Location
    Austin Texas
    Posts
    92
    U might be able to, but might take a good amount of tear down
  13. #13
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,381
    You could run wires from the metal tabs of the bulb holder for the middle light, to the other bulbs at the front.
    Make sure to disconnect the wires feeding the front bulbs now and reconnect the new ones.
    Be careful not to short the wires.
    I remember one guy fried his circuit when he tried what you want to do.
    It's a bit of a fancy circuit that dims the bulbs slowly to off.
    I'm pretty sure the circuit is in the cluster.
  14. #14
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,381
  15. #15
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,381
    ^^^ What he said
    I put a small solar panel on the sliding cover for the sunroof... It was a pain to feed the wires around.
    You can probably get an LED bulb for that middle light.
    You should disconnect your battery if you try to feed wires. There is constant +12 volts going to the middle light all the time. One short circuit and you could blow the circuit.
Similar Threads
  1. Headlight and dome light (in door switch) wont work
    By Macky14 in forum Mazda Protege
    Last Post: 08-29-2016, 07:08 PM
  2. turn on the dome lights when your open the cargo door?
    By seanhawk in forum CX-5 Accessories & Appearance
    Last Post: 05-26-2014, 08:01 PM
  3. Replies: 4
    Last Post: 10-10-2013, 04:49 PM
  4. Replies: 8
    Last Post: 01-02-2012, 12:17 AM
  5. Door open light on, no doors open?
    By Nutari in forum Mazdaspeed3
    Last Post: 06-18-2008, 11:34 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
