VersaTuner - tuning software for Mazdas
Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Thread: 2002 P5 A/C Compressor noise looking for an easy fix!
  1. #1
    Registered Member
    '02 Mazda Protege5
    Join Date
    Apr 2017
    Location
    Mount Kisco NY
    Posts
    19
    My AC system works , blows ice cold air but the compressor makes a freakin' racket. I can hear a fast knocking sound coming from it. It's mostly when its turned on but sometimes I can hear the same noise faintly when it's off. sometimes the belt squeals as well like when i first start it up and drive off. The clutch disengages when I turn off the AC but it seems to "Drag" a bit you can see it spinning slowly with the pully.
    I saw on another Mazda site, for Mazda 3/6 I believe, that there was a cheap fix for this as it may not require the compressor to be replaced, they just took the center clutch plate and pully out and replaced the bearing inside the pulley/clutch assembly, without even having to evacuate the refrigerant. IS this possible on the Protege5?
  2. #2
    Registered Member Corphish's Avatar
    83 RX-7 Gsl, 2000 Mazda Protege LX, 2011 Mazda3 Sport i
    Join Date
    Aug 2016
    Location
    Baldwin, WI
    Posts
    236
    Quote Originally Posted by wrathofpaul View Post
    Imho for the time it takes to do so I'd just replace the whole compressor. I have the same issue but as long as the ac still blows cold I'm not changing anything!
  3. #3
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,088
    Quote Originally Posted by Corphish View Post
    Imho for the time it takes to do so I'd just replace the whole compressor....
    You're supposed to evacuate then recharge the system to replace the compressor... And you're supposed to evacuate at a shop. A new compressor goes for $300- $450 CDN as well.
    There's a huge advantage to just replacing the bearing.
    I've never heard of anyone doing it on the P5 but it may be possible ???
    They do rebuild them so they must come apart somehow..
    I say go ahead and try to take it apart... You'll run the risk of breaking something then you'll Have to replace it, but you should be able to take the old bearing to a bearing place and match something up and it should be numbered.
    I'm assuming that your clutch might be damaged from a sloppy bearing and compressor parts don't seem to be available.
    Maybe something off a junker...
    The Diagram Dude
  4. #4
    Join Date
    Aug 2016
    Location
    Baldwin, WI
    Posts
    236
    Quote Originally Posted by pcb View Post
    Idk about you but if I asked a shop to evac my ac lines they would do so for free. I also know that ac tends to be more expensive that rolling the windows down so spending 300-450 would be about right. Rock auto has one for $230 or you can just find one from a junk yard.
    https://www.rockauto.com/en/catalog/...ompressor,6628
    Overall I would much rather spend the money on my ac then shred some belts due to a "drag" on the pulley and potentially strand myself.
  5. #5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,088
    I didn't think a shop would evacuate the AC for free.
    But I still think he should try to replace the bearing.. It could be a ten dollar fix.
    If something goes wrong he could just leave the belt off till he gets a replacement compressor.... He'll loose power steering and AC but the car will be driveable.
    If he shreds the belt, he may very well take out the other one at the same time, then he is pretty much stranded.
  6. #6
    Registered Member
    Protege5
    Join Date
    Jan 2015
    Location
    Springfield, MO Area
    Posts
    902
    You can take them apart, but it takes a special tool set to do so.
    Even then, you can't do it on the car, it still requires evacuation of the system.
    It's not the bearing anyway, these compressors just rattle, my P5 has been doing it for two years, my Ranger just started doing it too. And my brother's Miata does it. Run it until it quits, if it ever does.
    2002 Protege5 5 Speed, Pure White, FSZE Swap, Konig Incident 17's
    1998 Ford Ranger 2.5 5 speed
    1987 Mazda RX7, SBC swap in progress
    1998 Honda CBR900RR
    2013 Honda CB500F
  7. #7
    Join Date
    Aug 2016
    Location
    Baldwin, WI
    Posts
    236
    Quote Originally Posted by MrGiggles View Post
  8. #8
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,088
    ^^^ Good Answer !!!
    You'd swear MrGiggles knows a few things about cars !!!
  9. #9
    Registered Member
    '02 Mazda Protege5
    Join Date
    Apr 2017
    Location
    Mount Kisco NY
    Posts
    19
    Update: Problem solved! I was able to remove the clutch plate and pulley with bearing from the compressor without having to drain the freon. I replaced it with a new bearing/pulley/clutch from a rebuilt unit. noise is gone. A/c runs great now.
  10. #10
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,088
    Awesome !!!
    Any special tools required ???
  11. #11
    Registered Member
    '02 Mazda Protege5
    Join Date
    Apr 2017
    Location
    Mount Kisco NY
    Posts
    19
    Just a socket wrench and a pair of snap ring pliers. literally all I needed. undo the belt, unscrew the little bolt in the middle of the pulley, pull out the clutch plate (without losing any washers), take the snap ring out which holds the pulley on, slide it off and replace with new part. voila. saved over $500.
  12. #12
    Join Date
    Aug 2016
    Location
    Baldwin, WI
    Posts
    236
    Great now do a write up with pictures!
  13. #13
    SELECT * FROM DonutBox 323's Avatar
    (-_-) ...zZzzZzZZ
    Join Date
    Mar 2007
    Location
    757
    Posts
    4,758
    ive always had that rattling noise when the a/c engages. i've never thought anything about it. pics would be great! and part number for new part
    03 MSP, 03 P5
  14. #14
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,088
    So you did a great job of not removing your dash to fix your AC, proving the FSM wrong, but I'm kinda disappointed with your advice on the AC compressor...
    I think in an effort to redeem yourself, you should fix yours and your brothers clattering AC pump Without draining any freon... And post some pics so we can all do it...
    PS... I have the SST required (snap ring pliers)
  15. #15
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,088
    ..I replaced it with a new bearing/pulley/clutch from a rebuilt unit.
    How much was your rebuilt unit ??
    Aren't they expensive ???
Similar Threads
  1. A/C clutch noise? Or Compressor bad? Video included
    By rkhanso in forum Mazda5 Accessories & Appearance
    Last Post: 05-27-2015, 11:07 PM
  2. One easy Check Engine Light fix for 2002 Protege
    By Brcobrem in forum Mazda Protege
    Last Post: 03-27-2014, 12:33 AM
  3. 2002 Protege 5 Compressor ticking
    By Ed_PR5 in forum Protege5
    Last Post: 11-16-2013, 03:10 AM
  4. Replies: 15
    Last Post: 05-07-2012, 02:57 AM
  5. AC Compressor Noise
    By AIMWO4 in forum Mazda5 Engine & Transmission
    Last Post: 04-24-2010, 02:46 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
