Show your support and Donate!
Results 1 to 12 of 12
Thread: Roof trim?
  1. #1
    Registered Member
    Protege5
    Join Date
    Jun 2017
    Location
    Beaumont
    Posts
    19
    Roof trim?
    Need help finding trim to fit the seems of the oem roof rack after it has been removed, does anyone have a clue? IMG_0877.JPG
    Sent from my iPhone using Tapatalk
  2. #2
    Registered Member 915_P5's Avatar
    02 Mazda P5
    Join Date
    Feb 2010
    Location
    Hell Paso, TX
    Posts
    1,088
    Dealer and you need clips to cover the holes that grab on to the neW strips
    MSP HEADLIGHTS, MSP DOOR SILLS, MAZDASPEED AXLE BACK, S2K ANTENNA, REAR WIPER DELETE, FRONT PLATE RELOCATOR, TEIN COILOVER/STRUT SUSPENSION, OBX HEADER 4-1 W/ FOULER TRICK, K&N DROP IN FILTER, SPORT SHIFTER BASE, FRONT LIP, DIY FOGLIGHT MOD, COMPASS/TEMP MIRROR
  3. #3
    Registered Member
    Protege5
    Join Date
    Jun 2017
    Location
    Beaumont
    Posts
    19
    Quote Originally Posted by 915_P5 View Post
    Do you know if it'll be flush with the metal on the roof?
  4. #4
    Registered Member naguilar's Avatar
    2003 Sunlight Silver Mazda Protegé5
    Join Date
    Oct 2016
    Location
    NC
    Posts
    70
    Is it for a P5? I have a post up at the sale section.
  5. #5
    Certified Mazda Tech hornsfan10609's Avatar
    2003.5 Mazdaspeed Protege x2
    Join Date
    Jul 2009
    Location
    Austin, Tx
    Posts
    8,111
    Yes the 'roof fillter strips' are flush with the roof, like on the sedan.
    Mod List. "Jinba Ittai"
    2003.5 Titanium Mazdaspeed Protege #1345 Purchased 7/20/10
    2003.5 Titanium Mazdaspeed Protege #1574 Purchased 10/25/14
    2009 Highland Green Mustang Bullitt #5998 12.9@110
    2002 Red Protege5 RIP:4/25/10
  6. #6
    Registered Member
    Protege5
    Join Date
    Jun 2017
    Location
    Beaumont
    Posts
    19
    Quote Originally Posted by hornsfan10609 View Post
    Thanks for the info man
  7. #7
    Registered Member
    2002 Mazda Protege5
    Join Date
    Feb 2015
    Location
    Gates, NC
    Posts
    122
    Where can I get the clips you stick onto the car to secure the strips? I'm in the process of swapping out the rack and the stealership gave me the wrong clips.
  8. #8
    02 Mazda P5
    Join Date
    Feb 2010
    Location
    Hell Paso, TX
    Posts
    1,088
    Dealer item only
  9. #9
    Registered Member
    2002 Mazda Protege5
    Join Date
    Feb 2015
    Location
    Gates, NC
    Posts
    122
    Dealer item only
    Thanks, I ended up digging further on the forums and found the link to them, already have them ordered.
  10. #10
    Registered Member DirtyJack's Avatar
    Mazda P-5
    Join Date
    Oct 2011
    Location
    Tampa,FL.
    Posts
    15
    Thumbs up
    If its the link for the strips,could you post it here? I had/have the the caps that filled the area where the hard plastic caps fit in place of the rack when you remove the crossbars.but that plastic is nearly dead and crumbling.It has only lasted about 4 years and was not cheap from the dealer.
    If you have a link for something to fill the channel instead front to back it would be awesome!
    Thanks.
  11. #11
    Registered Member
    Protege5
    Join Date
    Jun 2017
    Location
    Beaumont
    Posts
    19
    Quote Originally Posted by DirtyJack View Post
    Thanks.
    Hey sorry for the late reply sadly I have no helpful links. What I did was removed the whole roof rack from the inside of the roof liner to the outside. It left holes but that's fine, I ordered ten roof clips from an OEM Mazda parts dealer online after that I went to a Mazda dealer and ordered roof MOLDINGS for the gaps where the roof each used to be. Some people call them roof trim but I found out they are moldings. I actually went the expensive route but that was just preference. Any other information just msg me my man!
  12. #12
    Join Date
    Jul 2009
    Location
    Austin, Tx
    Posts
    8,111
    The filler strips and hardware is going to run about $200 from a dealer or around $100 here on the forum for used parts. If you get lucky and find an 03.5 at a junkyard with the roof rack delete you can get them for a few bucks.
Similar Threads
  1. Roof Gutter Trim Missing
    By rxe5006 in forum CX-5 Lounge
    Last Post: 03-23-2017, 08:14 PM
  2. Wtb p5 rear roof rack outer trim
    By CoTa in forum Want To Buy
    Last Post: 01-20-2015, 06:38 PM
  3. Plastic roof trim strip
    By 14M6GT in forum Mazda6 Accessories & Appearance
    Last Post: 06-30-2013, 05:38 PM
  4. Painting roof but What about trim removal ?
    By TimCosmo in forum Rotary Mazdas
    Last Post: 09-04-2012, 03:15 PM
  5. WTB: Roof rack trim pieces
    By Matt V in forum Completed Transactions
    Last Post: 06-21-2010, 01:04 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
