HOW TO 2016.5 : Eliminate side-to-side console movement.
superlario
MAZDA 2016.5 CX 5-T
If it bothers you, a pretty simple fix to eliminate the side-to-side console movement.
Cut a 1/2" piece of self-sealing closed cell pipe insulation to around 3". Fold it on itself.
Wedge it between the the inner back edge of the front season on each side, and the back side of the console housing on each side. In most cases, unless you move either seat fore or aft a lot, the wedged foam will stay in position.
Problem solved.
Latest posts
