CorkSport.com is MAZDA PERFORMANCE!
Results 1 to 15 of 15
Thread: Alternator Belt Tension
  1. #1
    Registered Member
    Protege5
    Join Date
    Jul 2017
    Location
    San Diego
    Posts
    6
    The protege5 service manual says that when inspecting the belt tension it should be 88 lb-ft. It says when replacing the belt to set it between 110-150 lb-ft. I took off the belt to install a new one and don't understand the difference in the two settings. I also removed the AC belt and need to put it back on to the correct tension.
  2. #2
    Registered Member Ban-Hammer's Avatar
    Mazda Protege5
    Join Date
    Oct 2016
    Location
    OR
    Posts
    44
    It should have no more that 1/2" deflection, IIRC
  3. #3
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,378
    Quote Originally Posted by Wiggybaby 67 View Post
    A general rule of thumb is reach in and twist the belt....
    If you can't stand it up sideways, it's too tight..
    If you can turn it upside down,... It's too loose....
    If you over tighten your belt, you'll wreck the bearing...
    If it's under tightened she'll scream like a banshee...
    Good luck with the balancing act...
    I'm on my fourth alternator...
    Sent from my 7040T using Tapatalk
    The Diagram Dude
  4. #4
    Registered Member
    Protege5
    Join Date
    Jul 2017
    Location
    San Diego
    Posts
    6
    Thanks, I tried that and think I have it right. Not squealing so must be tight enough. Can turn it sideways, so not too tight either. Not sure how many alternators came before this, it has 236,000 miles on it and I only account for 80,000 of those.
  5. #5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,378
    Three of my four alternators, had the bearing go out.
    Before I started doing my own work on my car, I would take it in for service.... The mechanics just cranked the hell out of the belt.
    It never squealed but the bearing would crap out in 6 months.
    (a bad bearing sounds a lot like a belt squealing...)
  6. #6
    Registered Member
    2003 Mazda Protege5
    Join Date
    Oct 2015
    Location
    Dallas, TX
    Posts
    85
    Quote Originally Posted by pcb View Post
    This is exactly what I've been going through for the past year or so...my Mazda friend/mechanic changed the belt, it helped for a little bit...but, he told me the alternator was going out and that it was the bearing in the alternator failing...I just can't bring myself to buy a new alternator! But, the squealing is getting out of control and I can barely have the A/C on without it going nuts, and it's HOT here in Texas!
    Any advice on a decent replacement? I really don't wanna drop $400...
  7. #7
    Registered Member
    2003 Mazda Protege5
    Join Date
    Oct 2015
    Location
    Dallas, TX
    Posts
    85
    So, what do y'all think is a decent replacement alternator?
    http://www.rockauto.com/en/catalog/m...generator,2412
    NEW Pure Energy Alternator - $156.79
    REMAN Denso - $109.79
    A friend of mine seems to be a Denso brand loyalist, I'm curious as to others' opinions! Please share!
  8. #8
    Registered Member
    Protege5
    Join Date
    Jan 2015
    Location
    Springfield, MO Area
    Posts
    927
    I'm sure the Denso will be fine.
    2002 Protege5 5 Speed, Pure White, FSZE Swap, Konig Incident 17's
    1998 Ford Ranger 2.5 5 speed
    1987 Mazda RX7, SBC swap in progress
    1998 Honda CBR900RR
    2013 Honda CB500F
  9. #9
    Registered Member
    2003 Mazda Protege5
    Join Date
    Oct 2015
    Location
    Dallas, TX
    Posts
    85
    Quote Originally Posted by MrGiggles View Post
    That's what I'm leaning towards...what do you think about the difficulty level of this repair? I've done LCAs, axles, oil, gear oil, rotor, brakes, calipers...I have a mechanic friend at Mazda that quoted me $80 for the repair, I believe. Not sure if it's worth the headache to save the $80...I'll do some digging on here about the repair.
  10. #10
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,378
    The alternator unbolts quite easily.
    The problem is that the alternator is trapped in the engine bay,... There's a few ways to deal with it.
    https://www.mazdas247.com/forum/show...the-alternator
  11. #11
    Registered Member
    2003 Mazda Protege5
    Join Date
    Oct 2015
    Location
    Dallas, TX
    Posts
    85
    Thanks for your reply, I read the post you linked earlier...I meant to come back and reply that I think I could handle the repair, so I went ahead and bought the DENSO reman! Wish me luck!!!
    Oh, should I go ahead and replace belts at this time..? Depending on condition?
  12. #12
    Registered Member
    Protege5
    Join Date
    Jan 2015
    Location
    Posts
    927
    Quote Originally Posted by mattzerstoren View Post
    I think it'd be silly not to.
  13. #13
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,378
    That wouldn't be silly,... That'd be stupid...
    Or you could spend $20-$30 for a different brand... (a lot less in US dollars)
    PS and by the way... A new belt is kinda fuzzy and grips the pulley better.
    As little as a minute of squealing can "glaze" the belt and make it all slippery.
    A new belt gets tightened up tighter because there is some stretch....
    5 minutes running time makes it a used belt...
    Run it five minutes and readjust.
    (belt dressing or even hairspray can make a belt grip better and not squeal... better than a new alternator... )
  14. #14
    Registered Member
    2003 Mazda Protege5
    Join Date
    Oct 2015
    Location
    Dallas, TX
    Posts
    85
    Cool cool, I'll get some new belts on there...I'll run it for a few and re-adjust...do y'all use a belt tension gauge to measure tension, or just roll the belt over and judge by how far it moves..?
    Also, any particularly great brands for belts in the US?
  15. #15
    Registered Member
    2003 Mazda Protege5
    Join Date
    Oct 2015
    Location
    Dallas, TX
    Posts
    85
    FINALLY got this repair done! I went with the DENSO reman alternator, two new belts, and all is right in the world! My P5 is running like a champ, and no more squeal!!!
    THANKS Y'ALL!
Similar Threads
  1. alternator and time belt tension
    By Pmazda5 in forum Protege5
    Last Post: 12-29-2015, 11:14 PM
  2. Timing belt tension pully/idler pulley
    By TDiLisio in forum Mazda Protege
    Last Post: 10-01-2012, 08:57 AM
  3. belt tension? or something else?
    By Ride92 in forum Protege5
    Last Post: 02-21-2010, 04:32 PM
  4. Any Alternative Way To Check Belt Tension?
    By carter1551 in forum Protege5
    Last Post: 05-07-2008, 10:37 PM
  5. Belt tension? Snapped a Gatorback on the alternator
    By nater006 in forum Mazda Protege
    Last Post: 03-10-2008, 05:42 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
