Rear Lateral Link Replacement parts?
02 Protege 5
I am redoing the suspension in the rear of my P5 and need to replace the rear lateral links. Are all 4 identical to each other? On Rockauto there are several different brands and i am not sure what parts to order. I know there is a difference with the in the length if you have drum brakes which I don't.
Judging by the diagram, the front and rear lateral links look quite different.
You'll need to lower your cross member to get at the bolt.
All P5's have four wheel disk brakes and sport suspension. Sometimes Rock Auto doesn't have all the information.
Perhaps they are out of the proper parts for our car ??
Sounds like you might end up with the wrong parts??
You might want to order from somewhere else for those parts.... Somewhere that doesn't ask if you have drum brakes or sport suspension.
Rear rearward c10028600b can find at mazda or aftermarket(ebay, amazon)
front rearward b30p28620a only found at mazda
THESE ARE THE PART #'S FOR THE MP3, SHOULD BE THE SAME. WHAT I DID WAS CALL MAZDA GOT THE PART #'S AND SHOPPED AROUND AND GOT THE 2 FROM MAZDA AND THE THE OTHER 2 FROM EBAY.
