VersaTuner - tuning software for Mazdas
Results 1 to 7 of 7
Thread: Rusted brake lines
  1. #1
    Registered Member
    Protege5, 2003
    Join Date
    Oct 2011
    Location
    OH
    Posts
    18
    Question Rusted brake lines
    Inspected the car today when the mechanics were doing the brake work and found the brake lines in bad shape. Have a upcoming highway drive about 2hrs this Friday and wondering if this is going to be OK. As shown in the pictures, the straight part of the brake lines are all rusted and seem dangerous...
    1. I am thinking of replacing just this part by cutting above the bending-up, do the double flaring and connect the new lines back. I have never done double flaring myself, so I am wondering if it is possible to do it under the car. Will the tools fit into the space? Presumably I can buy a roll of brake line and practice until I master the technique and create the straight part. But will I be able to connect them back?
    2. The line holders are pretty rusted, too. Any solution if I fail to install them back? Or shall I just install some new holders next to them? Dealing with rusted nuts is frustrating...
    Any feedback will be helpful. Thanks in advance!
    WeChat Image_20170613184732.jpgWeChat Image_20170613184738.jpgWeChat Image_20170613184742.jpgWeChat Image_20170613184746.jpg
  2. #2
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,499
    Quote Originally Posted by redbaron112358 View Post
    ... Presumably I can buy a roll of brake line and practice until I master the technique and create the straight part. But will I be able to connect them back?
    Get this stuff dude...
    It's mostly copper... Won't rust,... And is soft enough to flare real nice....
    Practice on some small pieces then flare away.
    Replace the entire length... "Splicing"or compression fittings aren't legal (or safe)
  3. #3
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,499
    Don't remove them... Just pull the old brake lines out of them and pop the new ones in. (cut your old lines a few inches back from the holder and pull)
    If they're stuck and don't wanna come out just zip tie your new lines to the holder. (try not to have your new lines as the lowest point of the car in case you bottom out in something)
  4. #4
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,499
    I just realized those were pictures attached at the end of your first post...
    All those lines look pretty damn shitty..
    You've got a fuel fed line (fat one I think) fuel return line and a vapor line.
    Try really hard not to disturb them or you'll end up replacing everything... Just trying to remove the bracket/holder might be the last straw for the whole batch of lines.
    Those bolts may thread into weld nuts on the other side.. . the welds like to break then the bolt just spins.
  5. #5
    Registered Member
    Protege5, 2003
    Join Date
    Oct 2011
    Location
    OH
    Posts
    18
    It indeed look really shitty. Not sure if I should even drive it onto the highway...
    Thanks for the great explanations.
  6. #6
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,499
    Those fuel lines are PITA..
    I don't know if you can buy those clips/connectors for the ends or if they're specially flared tubing ???
  7. #7
    Registered Member
    Protege5, 2003
    Join Date
    Oct 2011
    Location
    OH
    Posts
    18
    This start to look like a serious project that requires many hours of work. I am not sure I can handle it myself, giving that I only have limited tools and no garage... I guess it would cause me a fortune if bringing it to mechanics...
Similar Threads
  1. SS brake lines
    By Rogue in forum Mazda Protege
    Last Post: 11-26-2004, 12:46 AM
  2. Brake lines?
    By Jake1 in forum Mazdaspeed3
    Last Post: 10-08-2004, 09:31 PM
  3. Rusted brake rotors
    By Coqui258 in forum Protege5
    Last Post: 11-05-2003, 12:22 PM
  4. New Brake Lines
    By Spicy1390 in forum Mazdaspeed Protege
    Last Post: 10-23-2003, 01:25 AM
  5. which brake lines fit?
    By SuperSpud in forum Mazdaspeed Protege
    Last Post: 07-16-2003, 07:52 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
