CorkSport.com is MAZDA PERFORMANCE!
Results 1 to 10 of 10
Thread: 02 P5 Rear brake caliper issue
  1. #1
    Registered Member
    Car
    Join Date
    Mar 2015
    Location
    NY
    Posts
    95
    Hey guys, i have a 02P5 with 120K on it. I noticed the other day both my rear rotors were rusted (both sides) . Seems like my calipers gave out on me and are not making contact with rotors. Even when i put my e brake on doesnt seem to hold car on place much. I tried removing the rear passenger side but could not get the caliper to full swing all the way open/up in order to remove it. I did order rebuilt A1 cardone calipers for both sides.
    Any recommendations? I didnt remove the screw on the back of the caliper that retracts the piston. Do you guys think that will help?
  2. #2
    Registered Member Corphish's Avatar
    83 RX-7 Gsl, 2000 Mazda Protege LX, 2011 Mazda3 Sport i
    Join Date
    Aug 2016
    Location
    Baldwin, WI
    Posts
    255
    Retracting the caliper may help but if it's just rusty I'd say partially swing it up and stuff a pry bar or even a beefy flat heat in there and pry
  3. #3
    Registered Member
    Car
    Join Date
    Mar 2015
    Location
    NY
    Posts
    95
    tried a beefy flat head and no luck, maybe a pry bar is needed. I will attempt again after this heat goes away lol.
  4. #4
    Join Date
    Aug 2016
    Location
    Baldwin, WI
    Posts
    255
    I don't really know what your circumstances are either maybe take some pictures and upload them.
  5. #5
    ......................... i12drivemyMP5's Avatar
    Donated: $5
    323F
    Join Date
    Apr 2005
    Location
    Posts
    7,409
    Sounds like pads have worn a lip around the outside of the rotor and the pads are catching on lip and not coming off. If that is case then yes, retract the pad screw and it should let loose of it.......
  6. #6
    Registered Member
    2003 P5
    Join Date
    Jan 2005
    Location
    Colorado Springs, CO
    Posts
    43
    Have you tried tightening the pad retractor screws to see if you can get the pads to make contact with the rotors?
    If your pistons and/or guide pins are totally frozen it won't help, but if they still move the screw can be used to close the pad-rotor gap for wear.
    They are supposed to adjust automatically, but when they get sticky/rusted that goes out the window. Your statement about the parking/e-brake
    not working correctly is a key clue.
    Same thing when you install new ones - with the e-brake off, rotate your calipers so that the bleed screws are the highest point in the system and
    bleed the air out. Rotate them back into their normal position and bolt them down, then tighten the retractor screws until the pads just start to grab
    the rotors and back off about a half-turn.
    After that your e-brake should work correctly and you should have a nice hard brake pedal with no mush.
  7. #7
    Registered Member
    Protege5
    Join Date
    Jan 2015
    Location
    Springfield, MO Area
    Posts
    936
    Take out the two bolts that hold the caliper bracket to the hub and toss the assembly in the scrap pile.
    If the sliders are frozen that bad, you'll be time and money ahead to get new brackets and hardware too.
    2002 Protege5 5 Speed, Pure White, FSZE Swap, Konig Incident 17's
    1998 Ford Ranger 2.5 5 speed
    1987 Mazda RX7, SBC swap in progress
    1998 Honda CBR900RR
    2013 Honda CB500F
  8. #8
    Registered Member
    2003 Protege5
    Join Date
    Jun 2017
    Location
    Massachusttes
    Posts
    12
    I just did the rear calipers on my 03 p5 so the ebrake would function as well. Not sure how your calipers are but both back were seized. Advanced auto sells the whole assembly for 150 per caliper 70 dollars back if you bring the old core.
    Sent from my VS987 using Tapatalk
  9. #9
    Donated: $5
    323F
    Join Date
    Apr 2005
    Location
    Posts
    7,409
    damn road salt.................
  10. #10
    Registered Member
    2003 Protege5
    Join Date
    Jun 2017
    Location
    Massachusttes
    Posts
    12
    Quote Originally Posted by i12drivemyMP5 View Post
    Yeah, driving a protege in Massachusetts is sad
Similar Threads
  1. Replies: 13
    Last Post: 02-12-2016, 08:59 PM
  2. Mystery brake caliper fit issue
    By Fejwe in forum Mazdaspeed Protege
    Last Post: 10-24-2013, 11:57 PM
  3. brake caliper issue
    By rae rae in forum Mazda MP3
    Last Post: 05-07-2011, 07:30 PM
  4. Do I need a new rear brake caliper?
    By Wildfyre in forum Mazdaspeed Protege
    Last Post: 05-29-2010, 12:25 AM
  5. WTB: Rear Right Brake Caliper
    By b_dues in forum Completed Transactions
    Last Post: 06-30-2009, 03:37 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
