VersaTuner - tuning software for Mazdas
Results 1 to 8 of 8
Thread: Repair Opinons
  1. #1
    Registered Member
    protege5 2002
    Join Date
    Jun 2017
    Location
    los angeles
    Posts
    2
    Repair Opinons
    Hello,
    How bad is this?
    Is this ok to lube up and assemble? or would I have to replace?
    IMG_4844
    IMG_4846
  2. #2
    MSP #156 PSUENGR's Avatar
    2003.5 MAZDASPEED Protegé
    Join Date
    Jun 2004
    Location
    Chicago Suburbs
    Posts
    197
    I have no experience with internals, so you probably shouldn't listen to me, but that doesn't look good. Was the engine starved for oil? Looks like there was lots of metal on metal going on.
    What made you open it up in the first place?
    Sent from my SM-N910P using Tapatalk
  3. #3
    Registered Member
    protege5 2002
    Join Date
    Jun 2017
    Location
    los angeles
    Posts
    2
    yes, it was starved of oil. I was going to do an oil change over the weekend but the timing belt snapped while i was driving on the freeway under 15 mph.
    I read that it may or may not be an non interference engine.
  4. #4
    Join Date
    Jun 2004
    Location
    Chicago Suburbs
    Posts
    197
    Not good.
    You need someone to chime in who can judge the severity of the material loss. I would assume that it will only get worse if it's not machined smooth again but tolerances may not allow you to do that.
    Reminds me I should check my belt and see when I changed it last.
  5. #5
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,756
    Quote Originally Posted by madness500 View Post
    Engine damage (bent valves) after snapping a timing belt is VERY Rare... Only a few guys have had it happen.
    It's well worth putting a new belt on it.
    As far as your pictures go,... That looks really wrong. (but I don't know much about engine internals either).
    You could score a used camshaft and parts off a junker for quite cheap.
  6. #6
    Registered Member nokturnal's Avatar
    spicy orange mazdaspeed protege
    Join Date
    Apr 2015
    Location
    sandiego ca
    Posts
    70
    u might be able to get the cams polished unless they are scratched bad but that cap might need to get replaced
    Might wanna check the valves
  7. #7
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,756
    Quote Originally Posted by nokturnal View Post
  8. #8
    Registered Member
    Protege5
    Join Date
    Jan 2015
    Location
    Springfield, MO Area
    Posts
    957
    Yeah, if you have damage like that up top, you can bet that there is damage in the lower end too.
    I'd start looking for a motor.
    2002 Protege5 5 Speed, Pure White, FSZE Swap, Konig Incident 17's
    1998 Ford Ranger 2.5 5 speed
    2013 Honda CB500F
Similar Threads
  1. need some opinons on exhaust PLEASE!
    By proteged in forum Mazdaspeed Protege
    Last Post: 02-03-2012, 07:23 PM
  2. opinons???
    By coty101 in forum Mazda6 Lounge
    Last Post: 06-02-2010, 02:31 AM
  3. Looking to buy, want opinons/reviews...
    By Wizard Of ID in forum Mazda MP3
    Last Post: 01-10-2008, 12:07 PM
  4. Opinons
    By redmption in forum Off Topic
    Last Post: 01-26-2004, 12:01 PM
  5. Opinons please
    By MazdaDryvr in forum Mazdaspeed Protege
    Last Post: 08-22-2003, 10:43 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
