VersaTuner - tuning software for Mazdas
Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
Thread: No air coming out of vents.
  1. #16
    Registered Member
    Mazda Protege5
    Join Date
    Sep 2016
    Location
    CA
    Posts
    139
    Quote Originally Posted by pcb View Post
    You may have a bad blower relay...
    For you to have no wind at all at any fan speed or flickering of the AC light, suggests that relay...
    You could test to see if power is getting through the relay... See if you here it clicking...
    (I don't know if it would click with the ignition or turning the fan on... probably ignition)
    I've heard clicking before but only when I engage on push on the cruise control button.
  2. #17
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,804
    Checking your fan switch and connector is relatively easy to do.
    There is a bunch of relays in that corner... Try to isolate it and listen,... You may be able to feel it click too.
    You can test it by supplying power to it.
  3. #18
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,804
    Check your Heater fuse too... #1
    I'm pretty sure that means blower motor...
  4. #19
    Registered Member 915_P5's Avatar
    02 Mazda P5
    Join Date
    Feb 2010
    Location
    Hell Paso, TX
    Posts
    1,106
    Same happened to me when i bought the p5, seller claimed ac did not work at all. So what i did was removed the blower motor, when removed i turned the wheel and i heard a cracked like i broke the dirt between the wheel. Then i rinsed it off with very hot water, let dry for awhile and blower motor worked.
    MSP HEADLIGHTS, MSP DOOR SILLS, MAZDASPEED AXLE BACK, S2K ANTENNA, REAR WIPER DELETE, FRONT PLATE RELOCATOR, TEIN COILOVER/STRUT SUSPENSION, OBX HEADER 4-1 W/ FOULER TRICK, K&N DROP IN FILTER, SPORT SHIFTER BASE, FRONT LIP, DIY FOGLIGHT MOD, COMPASS/TEMP MIRROR
  5. #20
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,804
    Quote Originally Posted by 915_P5 View Post
    Never heard of that one...
    I suppose the smart thing to do would be to trace the voltage through all the wires, switches and connectors.
  6. #21
    Banned
    jbxwiotb
    Join Date
    Jun 2017
    Location
    jbxwiotb
    Posts
    4
    Hình ảnh truyền hình cáp viettel quảng ngãi
    đường dây nóng Ưu điểm viettel quảng ngãi
    Các mốc PT quan trọng của truyền hình cáp việt nam
    – 20/9/1995: trọng tâm DV cáp kĩ thu*t MMDS được hình th*nh
    – Tháng 12/1995: doanh nghiệp truyền hình cáp S*i Gòn (SCTV) được b*n giao quản
    – Tháng 12/1996: Máy phát sóng được nâng cấp lên 6 kênh với bán k*nh 40km
    – 25/4/1998: khởi đầu khóa mã v* bán bản quyền truyền hình
    – Năm 1999: Lúc n*y có 16 kênh v* 13 kênh khóa mã
    – 14/1/2000: có mặt trên thị trường Hãng truyền hình cáp Việt Nam ( VCTV)
    – Năm 2001: xây dựng thương hiệu cơ sở ở Hải phòng, TP HCM, Hải Dương
    – Tháng 4/2002: SCTV tách ra khỏi VCTV
    – 21/11/2003: trọng điểm kĩ thu*t truyền hình cáp Việt Nam ra đời. Mở thêm DV internet v* nhiều dịch vụ khác.
    – 1/11/2004: VCTV bắt đầu truyền hình số vệ tinh DTH v* phát sóng to*n quốc
    – 7/5/2013: Tổng công ty truyền hình cáp Việt Nam. Logo từ VCTV sang VTVCab
    Đến thời điểm hiện tại, số lượng các kênh của truyền hình cáp việt nam lên đến con số gần 100 kênh. Đây l* th*nh quả v* sự cụ không ngừng nghỉ của h*ng ngũ tổ chức trong 20 năm qua.
    http://viettelquangngai.net/dang-ky-...ai-viettel-ca/
    tư vấn mạng viettel quảng ngãi
    Hiện nay, với độ phủ sóng to*n quốc thì cái tên truyền hình cáp việt nam (VTVcab) đã trở th*nh quá thân thuộc đối với khán giả truyền hình. Cùng với đó l* sức PT mạnh mẽ v* t*nh giỏi cao.
    http://viettelquangngai.net/cung-tra...ai-quang-ngai/
    Photo mạng viettel quảng ngãi
    Bộ chia t*n hiệu truyền hình cáp v* dây dẫn
    Để kết nối một đường dây t*n hiệu truyền hình cáp với nhiều tivi, bạn cần có 1 thiết bị dùng để chia t*n hiệu truyền hình, gọi l* bộ chia (Spliter). Tùy theo số lượng Tivi m* bạn sẽ dùng bộ chia 2, 3 hay nhiều đầu ra. Bộ chia t*n hiệu n*y có thể mua tại các liên hệ bán đồ điện gia dụng, điển t*,...
    Dây cáp đồng trục, loại chuyên dụng cho truyền hình cáp đã được gắn đầu cắm. Dây n*y dùng để kết nối giữa bộ chia v* Tivi. Bạn có thể áng chừng chiều d*i dây dẫn cấp thiết v* nhờ nơi bán cắt v* giúp gắn đầu dây cáp hoặc có thể đem về tự đo v* gắn đầu dây.
    http://viettelquangngai.net/lap-dat-...p-ho-chi-minh/
    lắp đặt Ưu điểm viettel quảng ngãi
    Truyền hình cáp (Cable TV) ng*y c*ng thông dụng vì có hình ảnh sắc nét v* ổn định vì t*n hiệu truyền hình được kết nối thẳng tới tivi duyệt dây cáp m* không thiết yếu Anten. thường nh*t nh* phân phối chỉ lắp đặt dường dây đến một Tivi, Nhưng trong nh* lại còn có những Tivi khác nữa, phải l*m sao đây?
    http://viettelquangngai.net/tag/dang...el-quang-ngai/
    Google: đường dây nóng Khuyến mại viettel quảng ngãi
  7. #22
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,804
    ^^^ What's that crap ???
    We need a moderator to delete his post and account...
  8. #23
    ......................... i12drivemyMP5's Avatar
    Donated: $5
    323F
    Join Date
    Apr 2005
    Location
    Posts
    7,447
    Vietnamese.........how is that not obvious? Thought everybody spoke Vietnamese, lol...........
  9. #24
    Registered Member
    Mazda Protege5
    Join Date
    Sep 2016
    Location
    CA
    Posts
    139
    I took off the motor and the wheel and the only thing that really stood out was the little hose was dusty but everything else looked fine. I don't have a volt meter to check the power so I havent gotten around to that tbh.
  10. #25
    Registered Member
    2002 Mazda Protege5
    Join Date
    Aug 2017
    Location
    California
    Posts
    1
    Are you saying you've got air blowing on your feet and the windshield just not from the dash toward you ?
    Or do you have no wind at all like it's turned off ??
    I'm having this problem? Only blowing in my feet. Do you have a solution for this?
  11. #26
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,804
    Quote Originally Posted by shaneml View Post
    Make sure your control wire is connected behind the dial...
    There's a clip that holds the wire that probably disconnected.
Similar Threads
  1. Dusty smell coming from vents?
    By buyingconstant7 in forum CX-5 Lounge
    Last Post: 03-08-2016, 02:58 PM
  2. Smoke coming out of my vents, burnt up fan?
    By Finaldo in forum Protege5
    Last Post: 11-24-2009, 06:53 PM
  3. Smoke/exhaust coming through vents/hood from CP-E downpipe at idle
    By steefnap in forum Mazda6 Engine & Transmission
    Last Post: 08-23-2007, 03:59 PM
  4. Strange smell coming through vents?!?!!?
    By zzMSP03.5 in forum Mazdaspeed Protege
    Last Post: 08-25-2005, 07:50 PM
  5. smoke coming from a/c vents!!!!!!!
    By MP3Architect in forum Mazda How-To
    Last Post: 06-10-2005, 02:48 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
