Compare auto reliability with reliable results at TrueDelta.com!
Results 1 to 10 of 10
Thread: Can't Shift Into 1st or 2nd when stopped - after half hour or so of driving
  1. #1
    Registered Member BlueBomber's Avatar
    03 P5, 5-SPD
    Join Date
    Feb 2011
    Location
    Nanaimo, BC
    Posts
    56
    So here's my issue:
    Car is a 2003.5 Protege5
    ~152,000 km
    Car is in really good shape, but over the last few months it's developed a pretty major issue.
    After driving it for 30 - 45 minutes, I can't shift the damn thing into first or second gear from a stop. When the problem first started, I could still muscle it into gear, now, forget about it. Pumping the clutch helps, but barely.
    I have read a couple bookmarked threads I have, but I figured I start a new thread for my problem.
    I just had the clutch and brake hydraulic fluid flushed and the clutch pedal checked, still have the problem.
    I have a feeling the clutch is failing to pull out fully after it heats up to a certain temp.
    So where should I go from here? Master/Slave cylinder replacement or just get the clutch replaced?
    Thanks,
    BB
  2. #2
    Certified Mazda Tech hornsfan10609's Avatar
    2003.5 Mazdaspeed Protege x2
    Join Date
    Jun 2009
    Location
    Austin, Tx
    Posts
    8,132
    Does the clutch pedal hold pressure or slowly bleed down? Have someone push the clutch pedal to the floor and watch the clutch fork. The soft clutch hose could be expanding, the seals in the master or slave could be leaking (would be more consistent), the trans fluid could be low, the clutch could be wearing out or the synchros inside the trans may be shot.
    Mod List. "Jinba Ittai"
    2003.5 Titanium Mazdaspeed Protege #1345 Purchased 7/20/10
    2003.5 Titanium Mazdaspeed Protege #1574 Purchased 10/25/14
    2009 Highland Green Mustang Bullitt #5998 12.9@110
    2002 Red Protege5 RIP:4/25/10
  3. #3
    03 P5, 5-SPD
    Join Date
    Feb 2011
    Location
    Nanaimo, BC
    Posts
    56
    I can't see the clutch fork, I'm not actually working on the car myself, I don't have the location, knowledge, or TIME to get that deep into car repairs.
    Thank you for your advice, I will talk with my mechanic about your points and see what he thinks.
    It has to be something related to heat buildup (right??), because the clutch system works no problem until 30-45 minutes of driving, then it becomes inoperable.
    If the synchros were shot, wouldn't it be impossible to shift regardless of temperature or driving time?
  4. #4
    Registered Member
    Protege5
    Join Date
    Jan 2015
    Location
    Springfield, MO Area
    Posts
    960
    Quote Originally Posted by BlueBomber View Post
    Yeah, it's a clutch problem, not the trans.
  5. #5
    Registered Member
    2001 Mazda Protege5 Manual trans, sunroof and ABS, "Mighty Rat"
    Join Date
    Mar 2015
    Location
    North New Jersey
    Posts
    7
    Quote Originally Posted by MrGiggles View Post
    Had this same issue on my 2001 P5. Shifted great when cold, when hot it was a pain. Even worse in summer. Changed all shift bushings, smoother shifting when cold, but when hot same issue. Don't know when clutch was done (or if ever done, I bought car about 2 years ago with 148,000mi on it) Someone said hydraulics are worth a shot before clutch replacement. Quick logon to Rock Auto and I purchased slave/master and hydraulic hose for about 70 bux. Installed all parts and followed up with a bleed using Harbor Freight pneumatic vacuum bleeder. After that, no more issues. worth a try....cheaper and less work than a clutch R/R.
  6. #6
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,798
    Quote Originally Posted by fireship1 View Post
    Had this same issue on my 2001 P5...
    There was no 2001 P5... Only 2002 and 2003.
    My car was built in September 2001 but labelled 2002.
    The new crop of 2018 vehicles will be available in a month or two... We've got six months to go till 2018.
  7. #7
    03 P5, 5-SPD
    Join Date
    Feb 2011
    Location
    Nanaimo, BC
    Posts
    56
    I haven't had a chance to deal with it yet, unfortunately my family-hauler (Pathfinder) has issues that need to be dealt with first. When I get the time I am going to replace the master and release cylinders and the clutch line and cross my fingers hope to hell it solves it.
  8. #8
    03 P5, 5-SPD
    Join Date
    Feb 2011
    Location
    Nanaimo, BC
    Posts
    56
    So I finally got a few minutes to look at what it's going to take to replace the master and release cylinders. Looks pretty straightforward. The only thing that looks like a bit of bitch is disconnecting the master from the clutch pedal... any tricks I should know? From the schematic drawing it looks like it just slides right off, but oh how I've been wrong before.
  9. #9
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,798
    I could post the FSM info but photo bucket has decided I need to pay them for "third party hosting"....
    I think all my photos/diagrams are gone/blocked...
  10. #10
    Registered Member Ban-Hammer's Avatar
    Mazda Protege5
    Join Date
    Oct 2016
    Location
    OR
    Posts
    44
    Make sure you get a stainless steel clutch line. My clutch was super spongey and just replacing that line made it firm and consistent again. I got mine for like $18 on Amazon.
Similar Threads
  1. Replies: 5
    Last Post: 06-05-2013, 06:42 PM
  2. Do you down shift while daily driving?
    By thecavemankevin in forum Mazdaspeed3
    Last Post: 12-15-2009, 04:03 PM
  3. 5-AT Stopped Working while driving
    By sensinitas in forum Mazda5 Engine & Transmission
    Last Post: 07-20-2008, 03:43 PM
  4. Stick-Shift Driving School????
    By chuyler1 in forum NEMOC
    Last Post: 01-18-2006, 08:23 AM
  5. Ugh, 23 hour shift at work.
    By Mike R in forum Off Topic
    Last Post: 02-23-2004, 09:19 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
