CorkSport.com is MAZDA PERFORMANCE!
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: Trans cooler for 5 speed
  1. #1
    Registered Member 915_P5's Avatar
    02 Mazda P5
    Join Date
    Feb 2010
    Location
    Hell Paso, TX
    Posts
    1,105
    Has anyone done a trans cooler on a 5 speed or is it possible to do so. My mp3 when the weather is hot trans feels to be over working. Just replaced fluid about 1/2 a year ago or so. You opinions please
    MSP HEADLIGHTS, MSP DOOR SILLS, MAZDASPEED AXLE BACK, S2K ANTENNA, REAR WIPER DELETE, FRONT PLATE RELOCATOR, TEIN COILOVER/STRUT SUSPENSION, OBX HEADER 4-1 W/ FOULER TRICK, K&N DROP IN FILTER, SPORT SHIFTER BASE, FRONT LIP, DIY FOGLIGHT MOD, COMPASS/TEMP MIRROR
  2. #2
    MSP #156 PSUENGR's Avatar
    2003.5 MAZDASPEED Protegé
    Join Date
    Jun 2004
    Location
    Chicago Suburbs
    Posts
    197
    Are you tracking the car? There is no way you have an issue with normal street driving.
    That said I don't believe one exists and it likely wouldn't be easy to install any type of aftermarket one as the fluid never leaves the transmission.
    Sent from my SM-N910P using Tapatalk
  3. #3
    02 Mazda P5
    Join Date
    Feb 2010
    Location
    Hell Paso, TX
    Posts
    1,105
    In the morning i have no issues shifts smooth, but when the car sits for hours in the hot sun shifts get hard. Get scratching in 3rd and have to really put pressure in the shifter to put into 1st and light pressure into 2nd.
  4. #4
    Registered Member Corphish's Avatar
    83 RX-7 Gsl, 2000 Mazda Protege LX, 2011 Mazda3 Sport i
    Join Date
    Aug 2016
    Location
    Baldwin, WI
    Posts
    281
    I know what you mean my gf's Mazda 3 seems to do that when we lived in Arizona. But when I moved more north everything went well!
  5. #5
    Join Date
    Jun 2004
    Location
    Chicago Suburbs
    Posts
    197
    Perhaps you put the wrong fluid in when it was changed.
    Although I wouldn't think that would make it harder to shift when warm. Usually it's cold weather performance that you feel the difference
    Edit: or perhaps you didn't put enough fluid in. That could cause it to overheat.
    Ambient temperature shouldn't make a big difference in the operating temperature of the transmission fluid. Once it's warmed up out should remain around the same temp if your just doing normal driving
  6. #6
    Join Date
    Aug 2016
    Location
    Baldwin, WI
    Posts
    281
    Her fluid was and still is the fluid from factory.
  7. #7
    Registered Member NaturalFlavored's Avatar
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    394
    I live in Arizona where it's 100° plus everyday and I don't have a problem. I also put in Royal purple synchro mesh, had a clutch squeak changed transmissions fluid and throw out bearing stopped for a bit then came back. Got to the summer and it went away again.
  8. #8
    Join Date
    Jun 2004
    Location
    Chicago Suburbs
    Posts
    197
    What fluid did you put back in when you changed? It's possible that it could be the issue. I might try changing to a different brand like redline or royal prior to see if that solves your problem. Certainly a cheap thing to try...
  9. #9
    02 Mazda P5
    Join Date
    Feb 2010
    Location
    Hell Paso, TX
    Posts
    1,105
    Acdelco synthetic axle lubricant sae 75w-90
  10. #10
    Join Date
    Jun 2004
    Location
    Chicago Suburbs
    Posts
    197
    Quote Originally Posted by 915_P5 View Post
    That's the right weight at least.
    Try one of the better fluids and see if resolves the problem. And be sure to put the correct amount in. Can't remember for sure, but I think it is basically over flowing when it is full in this car.
  11. #11
    02 Mazda P5
    Join Date
    Feb 2010
    Location
    Hell Paso, TX
    Posts
    1,105
    In the shop manuel says to use 75w-90 or 80w-90, you think 80w-90 would work best
  12. #12
    02 Mazda P5
    Join Date
    Feb 2010
    Location
    Hell Paso, TX
    Posts
    1,105
    TRANSAXLE OIL REPLACEMENT [F25M-R]
    A3U051527001W02
    1. Remove the drain plug and the washer.
    2. Drain the oil into a container.
    3. Install a new washer and the drain plug.
    Tightening torque
    40—58 N·m {4.0—6.0 kgf·m, 29—43 ft·lbf}
    4. Remove the oil level plug and the washer. Add
    the specified amount and type of oil through the
    oil level plug hole until the level reaches the
    bottom of the oil level plug hole.
    Specified oil
    Grade: API service GL-4 or GL-5
    Viscosity: SAE 75W—90 (All season) or SAE
    80W—90 (Above 10 °C {50 °F})
    Capacity (approximate quantity)
    2.68 L {2.83 US qt, 2.36 Imp qt}
    5. Install a new washer and the oil level plug.
    Tightening torque
  13. #13
    Join Date
    Jun 2004
    Location
    Chicago Suburbs
    Posts
    197
    That should only affects the feel in cold weather
  14. #14
    02 Mazda P5
    Join Date
    Feb 2010
    Location
    Hell Paso, TX
    Posts
    1,105
    I'm going to try oem fluid and see if that works, if not may be could be the clutch or actuator.
  15. #15
    Registered Member
    2003 P5
    Join Date
    Jan 2005
    Location
    Colorado Springs, CO
    Posts
    53
    Take a good hard look at the clutch hydraulics - when normal fluids get warm,
    the viscosity drops (gets 'thinner') and if you have worn seals in either cylinder
    it can start slipping by them. If you have normal miles for the age of the car and
    they're still original, there's a good chance that one of them is ready for rebuild
    or replacement. Check the flex hose carefully for cracking, too. Mine failed once
    70 miles from home, luckily it was mostly interstate driving to get back. Had a
    flashback to my Kawasaki riding days for clutchless shifting...
Similar Threads
  1. Auto-Trans Cooler Hoses
    By psychoMP5 in forum Protege5
    Last Post: 09-26-2015, 02:27 AM
  2. Auto trans with trans cooler?
    By Sleezer1533 in forum Mazda Protege
    Last Post: 12-04-2011, 09:11 PM
  3. Factory Trans Cooler
    By CX9 SportOwner in forum CX-9 Accessories & Appearance
    Last Post: 04-20-2011, 05:29 PM
  4. Trans cooler installed
    By Tom03es in forum Mazda Protege
    Last Post: 06-28-2010, 09:29 AM
  5. trans cooler
    By Fade in forum Mazda Protege
    Last Post: 01-14-2005, 02:28 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
