- 2022 2.5GT
You know another thing about EPB: you won’t see any more folks pushing up and down the parking lever rapidly while in park to tighten the rear brake drum!!
BTW: can there be EPB and drum brakes?
There’s no reason why not but in fact drum brakes are very effective with little input because the shoes have a self servo effect. Sometimes vehicles with rear disc brakes have a small drum brake inside the disc (drum in hat) because they require less effort than attempting to apply the brake by clamping the pads.
In applications where a disc is necessary to meet the braking requirements of a higher performance vehicle, a simplified design uses the parking brake on the pads. This presents a problem as there is no self servo and the brake relies on clamping force only. This introduces a secondary problem in that unlike a drum brake where a cooling drum clamps the shoes even tighter, cooling discs contract away from the pads and it is not uncommon for a vehicle to run away. An EPB removes the risk as it over applies the brake via powerful springs that limit the applied force but maintain it when the brakes cool. It means that Miss Daisy can apply the parking brake with the same force as Iron Man and you need not fear for your life when she lives up the road from you. There are discussions taking place that will mandate EPBs on all cars.
Sorry for the long answer but mention brakes and I’m off on one!
