- 2014 QX70 AWD
I'm only posting this because it's the main reason I plan on moving on from my CX5.
Almost 2 out of every 3 cars I've owned over the years has had transmission problems, or symptoms pointing to transmission problems at some point. Mileage has ranged between 50k and 90k when the problems really started getting obvious. (Excluding current CX5). Not sure if it's just my bad luck... but it's always the damn tranny.
Cases in point, not necessarily in chronological order.
1990 Eclipse GSX (manual). Hard to get into multiple gears.
1995 3000 GT base (manual). Hard to shift into 3rd and 4th.
1991/2/3 Honda Accord LX or EX, don't recall. (auto). Rough/jerky shifts and occasionally hard to move between D, R and P.
1992 3000 GT VR4 (manual). Popping out of certain gears. (Mainly 2 & 3).. thus bad syncros
2001 4Runner (auto). Shifter would rock back and forth severely during acceleration. Rear diff rotted out before it got worse.
2016 CX5 (auto). Regularly takes 3 full pumps of the brake pedal to shift smoothly out of park.
This is why I really want a lifetime power train warranty on my next vehicle. Not that I want my trannys replaced, but that peace of mind would be so reassuring.
None of these symptoms were ever present during original test drives. Has anyone else ever experienced such similar flaws over a similar number of vehicles? I know I often have bad luck, but wowsa. Enough is enough.
Edit- cars with okay trannys:
1984 GTI (manual)
1982 Volvo 240 Turbo (manual)
1996 Elantra (manual). Winter beater
2005 Mazda 6 (manual)
1984 GTI (manual)
