VersaTuner - tuning software for Mazdas
Results 1 to 5 of 5
Thread: 2002 p5 occasional starter noise
  1. #1
    Registered Member
    '02 Mazda Protege5
    Join Date
    Apr 2017
    Location
    Mount Kisco NY
    Posts
    36
    Sometimes when I go to start the car it would make what can only be described as a "skipping" noise when cranking. Not really a grinding noise, it just doesn't make that steady "rr-rr-rr-rr-rr" noise. it will go "rr-rr-rr- rrrr- r-r--rr-rr-rr a few times until it eventually starts. or sometimes if I let it sit for like 10 seconds and try again it would be fine. It doesn't happen a lot it's only sometimes but I'm afraid it will get worse...
    Could it be the starter will need replacement soon? Is that an easy job on these cars?
  2. #2
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,756
    You might need a starter soon...
    It's not too difficult to replace.
    Apparently the bolts are a little difficult to reach.
  3. #3
    Registered Member
    '02 Mazda Protege5
    Join Date
    Apr 2017
    Location
    Mount Kisco NY
    Posts
    36
    I got the new starter. Installation looks like a piece of cake according to the Haynes. Is there anything I need to know about making sure the gears mesh properly? I read somewhere that you have to properly "Shim" the starter and I have no idea what that is. does that apply to our cars?
  4. #4
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,756
    Quote Originally Posted by wrathofpaul View Post
    I'm pretty sure you just bolt the new one in...
    Nothing was mentioned in the service manual about shims or meshing gears.
    I didn't know there was a Haynes manual for our car...
    The one I found only covered 1990-1997.
  5. #5
    Registered Member
    BJII Astina SP20
    Join Date
    Apr 2016
    Location
    Australia
    Posts
    173
    Quote Originally Posted by pcb View Post
    There's a general Haynes manual that covers all Protégé's.
    https://haynes.com/en-us/mazda-323-p...-online-manual
Similar Threads
  1. starter making noise but no cranking
    By eyeballs in forum Mazda5 Lounge
    Last Post: 01-06-2014, 01:35 PM
  2. rear noise + misc (help) Protege ES 2002
    By neko11 in forum Mazda Protege
    Last Post: 01-31-2010, 09:37 AM
  3. 2002 protege5 ticking noise
    By banditbasser in forum Mazda Protege
    Last Post: 08-07-2009, 07:11 AM
  4. 2002 ES Starter Problem?
    By NauPruz in forum Mazda Protege
    Last Post: 01-29-2008, 09:38 PM
  5. Replies: 10
    Last Post: 10-23-2007, 11:13 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
