2016 BOSE Speaker Harnesses???
2016 Mazda CX-5 GT AWD w/Tech & i-Activesense
Has anyone come across a speaker harness for the Bose speaker system in the front dash locations yet? I have new Polk DB351's waiting to go in and would like to keep factory wiring intact if possible. I'm hoping the aftermarket industry has caught up by now and there is a solution out there.
On another note, does any one have the wiring diagram or can tell me which speaker wires are positive and negative?
I trimmed some speaker wire and soldered the tips, stuck them right into the OEM harness. It took a bit of trial and error to figure amount the right stripped cable length and amount of solder buildup to make it a firm connection but I haven't had a single issue with it. I also taped over it nice and tight for good measure.
Where can I find the harness with OEM plug to the Bose amp under passenger seat? I want to by-pass the Bose amp.
Thanks
Latest posts
