I wonder what's the ratio of each gear...
This is our ratios:
And they labelled my unit as 2018 model. However when you ask the sales agent the difference from the 2017 model, he couldn't answer. [emoji16]
The:This is our ratios:
The:
Electronic (Drive by wire)
Is for the steering, accelerator or the shifter?
Thats it. Not much point revving above 3000rpm. If I’m overtaking over a longer stretch, I use the manual gear change to force upshifts as flooring the accelerator holds the lower gear but its very unnerving when you lose all the acceleration. Its something that will take some getting used to if you have never driven a diesel. You’ll know exactly what I mean when you get to drive one.
I always floor the throttle in auto and it shifts plenty fast enough for me, revs up to 3000 rpm, only time I down shift in manual is when I have the 1700kg caravan on the back and want to overtake, even then its not every time.
I'm not sure what you mean about loosing all the acceleration.?
what is redline on the diesel?
Redline is 5200 RPM
Maximum power is at 4500 RPM
We're not getting the SBS & SCBS here. [emoji26]
It doesn't say anything regarding the SCBS & SBS which could only mean that we don't get those features. So we get the "3D" emblem.Doesn't your brochure mention anything (scratch)
We're not getting the SBS & SCBS here considering I'm getting the top tier model. [emoji26]
http://cloud.tapatalk.com/s/59a85a94371ad/All-New-Mazda-CX-5-5.9.17.pdf
Above 3000rpm, you've already past peak torque figures and redline is not that far away. Hence yes you are accelerating but at a slower rate than say during peak torque range.
Its the auto that changes at 3K revs, I'm sure Mazda engineers know what they are doing otherwise the change up would be earlier, I've also seen it higher than 3K on occasions.
Max power is quite high for a diesel, so although the torque is reduced max power isn't at its peak. And it red lines at 5200 rpm.
Ps the point where power crosses the torque graph is around 3,600 rpm.
Yeah. I've seen the foglights and it really doesn't make much difference for me in terms of brightness. I maybe wrong because I haven't gotten hold of my unit yet but judging from it's brightness when turned on.Nope... doesn't appear so. But you get LED fog lights across all trims....
https://www.mazda.ph/wp-content/uploads/2016/07/All-New-Mazda-CX-5-5.9.17.pdf
No laws regarding that but it's more on economy and profit. SRP of the "top tier" which is diesel is $43k!!!!Must be related to some sort of law in your country that doesn't allow this or possibly driving conditions
