6i 5 speed shifting issue
chmazda6
06 6I 2.2 5 spd
son is Driving our 2006 with about 145k on it. Clutch et al replaced in '09 when it had about 45k on it. Yesterday he called and said he can't get it to shift gears. Nursed it home and I see that the clutch is engaged all the time. Check the fluid level and its a bit low but not down to the master feed line. Look down at the slave while pedal is pushed, and there is movement on the lever, but apparently it is not disengaging the clutch. If the engine is off it will shift through the gears freely, so I believe the gear box is OK. Not prior symptoms of noise, slipping etc. Just all of a sudden won't disengage. Well maybe not suddenly, I have noticed that I would have to push the pedal pretty far down to disengage and get it to be able to shift.
Is it possible that the slave is not providing enough movement to throw out the clutch? Bleed in order? Replace slave? Anyone experience this?
Thanks
