- 2016 CX-5
fixed a shaky rear view mirror literally in 5 seconds, thought I'd share if some fellow CX-5 owners are experiencing the same this,
there's a Torx T20 screw at the bottom of the OEM rear mirror mount, just need to re-tighten and problem solved....
another benefit was what I though was an unreachable dash rattle turned out to be the mirror rattling over the bumpy roads....
after i tightened it the mirror is solid and not shaking anymore, plus the daily road that I took that had dash rattle surprising disappeared right after I tightened the mirror Torx screw..... hopes this helps someone in the same situation......
P.S.> sincere heartfelt thanks to all our veterans on Memorial Day
[url=https://ibb.co/gG8oXa]
