Over charging issue blowing head lights
Msp_tampa
Mazdaspeed protege
I had this issue before and had the alternator rebuilt at a local shop, it didnt solve it. The car runs fine driving around under normal acceleration 13.8 - 14v the problem is when you accelerate quickly towards redline the windshield wipers start going off, the tach dies, and the head lights blow out. My turbo timer says 17v towards 6400 rpm. Not sure i read voltage regulator is in the ecu. Any ideas thanks!
Wow, not familiar with this one. I would suggest another MSP ECU or swap the alternator. Have you had the alt bench tested? The voltage is regulated by the ECU. How do the fuses look? Is the main fuse intact and still a 100amp fuse?
