active head up display
Honda Prelude 2001
is it me or the setting doesn't save? i lower the image but once the car is restarted it goes back to default height. Am i doing something wrong here?
To save the preferred height of the HUD you must save it with the memory seat setting 1 or 2...it is also tied into the keyfob (if you save the seat settings). When you open the door the seat and HUD will adjust to the saved setting on the keyfob used...sounds like you made an adjustment on the HUD without saving it (memory seat
Thanks that must be it.
