ONIONSLAYER
- 2003 Mazda Proteg5
Hello Mazda community! Today I started having an issue with the cooling in my P5. I bought the car about a month ago, it's in fairly good condition minus normal old car stuff. (fluids, motor mounts, wheel bearings etc.) Along with an alternator that is starting to stuggle (I believe this is from the 1000 watt amp in the back). After I bought the car one of the first things I did was change engine fluids. This included an oil change and an antifreeze flush. I flushed the antifreeze untill it can out clear. After changing the fluids the car seemed much perkier and happier, untill today. On a commute around 45 mins ago I could smell a burnt antifreeze smell at some stop lights. Figuring that I had just changed the fluids I thought that somebody else must have a leak. When I arrived at my destination the little engine temp needle was right in the middle where it should be and I could still smell that burning antifreeze smell. So I popped the hood and took a look around. First thing I did was look in the over flow reservoir, it was a little merky but mostly clean and fresh looking. I grabbed a rag and slowly tried to take of the radiator cap to have about one table spoon of nasty muddy looking fluid come out before I closed it back up. I then decided to turn it back on and let it idle so the fans could cool it down. This is when I also noticed only the drivers side fan was working. After around 5 mins of idling I shut it off and took off the cap. It wasn't pressurized but the smell of burning fluid was immediately back and intense. The fluid was nasty and had coated the bottom of the cap in a creamy layer of rust. Does anybody have any ideas as to why it could be doing this? Could the therostat be bad? This is my first post, so any suggestions on improving my thread quality is also appreciated!
