CorkSport.com is MAZDA PERFORMANCE!
Results 1 to 11 of 11
Thread: Eibach ProKit, bad ride quality. Any idea why?
  1. #1
    Registered Member
    Mazda Protege 5 (2003)
    Join Date
    Jul 2012
    Location
    Puerto Rico
    Posts
    76
    I recently installed new struts, boots, and Eibach Springs. I love the way my protege5 sits now but the rear seems overly "soft". The ride is bouncy in my opinion and others feel the same when they ride with me. My bump stops were destroyed so I bought KYB boots+bump for the front and moog for the rears (kyb wasn't available). Nothing was cut since the instructions didn't say to and Eibach apparently doesn't recommend it. Also I might have installed the bumps upside down (not sure if it makes a difference but flat part towards the flat part of the shock). Anyone else on Eibach feel the ride is pretty bad versus OEM? I'm on 205/45/16 tire...
  2. #2
    Team Pro5 Jackie chan's Avatar
    Pro5
    Join Date
    Mar 2011
    Location
    Seattle, WA
    Posts
    1,905
    My eibachs were great, didn't trim the bumpstops either.
    Sent from my SM-G900T using Tapatalk
  3. #3
    Registered Member Ilikebikes's Avatar
    06 Mazda 3 Hatchback GT
    Join Date
    Jul 2015
    Location
    Northern California
    Posts
    161
    How long have you had them on? Sometimes it takes a bit for things to "settle"
  4. #4
    Registered Member
    BJII Astina SP20
    Join Date
    Apr 2016
    Location
    Australia
    Posts
    175
    What shocks did you install? No point installing Eibach springs with cheap shocks.
  5. #5
    I break stuff. Preferio's Avatar
    Donated: $1.67
    2003 Mazdaspeed Protege 1660, 2004 Winning Blue RX8, 2005 Mazda6
    Join Date
    Mar 2011
    Location
    Knoxville, Tn
    Posts
    3,812
    I'm curious what struts you installed, too.
    My Eibachs were great on my MSP.
    ASE Certifications: A1, A4, A5, A8, C1, P2
    Mitsubishi-Fuso: Electr. Cert. 1, 2, 3 and 4
    2013 Mazda CX5 Touring
    2008 Mazda CX7 Touring
    2007 Mazdaspeed 3:
    2005 Mazda 6 S: Gone.
    2004 Mazda RX8: Gone.
    2003 Mazdaspeed Protege #1660: Gone and missed.
    2003 Mazda Protege5: Gone.
    2002 Mazda Protege5: Gone.
    1995 Mazda Miata Best $50 I've ever spent.
  6. #6
    Registered Member
    Join Date
    Jul 2012
    Location
    Puerto Rico
    Posts
    76
    Removed some crappy Stagg and went to KYB Excel (black), I know they aren't tokico or anything high end but I had them on stock springs and felt pretty nice. The Eibach have been on for about a month, so about 500+ miles.
  7. #7
    Certified Mazda Tech hornsfan10609's Avatar
    2003.5 Mazdaspeed Protege x2
    Join Date
    Jun 2009
    Location
    Austin, Tx
    Posts
    8,132
    Did you get the specific P5 Eibach springs or Protege sedan springs? The P5 rear springs have a higher spring rate, due to having a much heavier rear end.
    Mod List. "Jinba Ittai"
    2003.5 Titanium Mazdaspeed Protege #1345 Purchased 7/20/10
    2003.5 Titanium Mazdaspeed Protege #1574 Purchased 10/25/14
    2009 Highland Green Mustang Bullitt #5998 12.9@110
    2002 Red Protege5 RIP:4/25/10
  8. #8
    Registered Member
    BJII Astina SP20
    Join Date
    Apr 2016
    Location
    Australia
    Posts
    175
    Quote Originally Posted by RensoreK View Post
    Exact spring and struts as my P5 then. And I don't have any 'bouncy' or 'soft' feeling in the rear. It's so much better than the stock set up.
    BTW, my stock struts (front and rear) were Tokico branded and black. They are the original struts from brand new as I know the full history of my car. Struts have never been changed since new. I've read on here that the OEM shocks were made by KYB. Strange.
    Quote Originally Posted by hornsfan10609 View Post
    I think you might be onto it!
  9. #9
    Registered Member
    Join Date
    Jul 2012
    Location
    Puerto Rico
    Posts
    76
    The ProKit is 5541.140 which I believe is the P5 version. Does the orientation of the bump stops matter? Since it will compress at the softest point anyway I assume. I installed them with the smaller taper side up, larger diameter towards the bottom. The original ones disintegrated so I'm not sure how they were lol.
  10. #10
    Join Date
    Jun 2009
    Location
    Austin, Tx
    Posts
    8,132
    Yes that is the correct P5 spring kit, the bump stops won't affect the ride unless the springs/struts are completely bottomed out. You should not be riding on the bump stops.
  11. #11
    Registered Member
    Join Date
    Jul 2012
    Location
    Puerto Rico
    Posts
    76
    Turns out the Moog Strut Boot Kit has a slightly longer bump stop in the rear and it was providing minimal strut travel. I removed about 1" of it from the rears and there was a 50-60% improvement. Now it's actually driveable. I will try trimming the front 0.5" (KYB) to see if I can also get a bit more travel in the front.
Similar Threads
  1. Eibach Springs - Ride Quality
    By inspekt in forum Mazda2 Lounge
    Last Post: 02-18-2014, 12:18 PM
  2. WTB Eibach Prokit
    By CasMs3 in forum Completed Transactions
    Last Post: 02-17-2010, 04:22 PM
  3. So how does everyone like there eibach prokit?
    By 09speed3 in forum Mazdaspeed3
    Last Post: 01-09-2009, 11:57 PM
  4. B&G vs Eibach ProKit
    By vyse12012 in forum Protege5
    Last Post: 03-08-2005, 02:44 AM
  5. Eibach prokit for MP5
    By hellcat in forum Mazda Protege
    Last Post: 09-28-2003, 11:42 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
