CorkSport.com is MAZDA PERFORMANCE!
Results 1 to 6 of 6
Thread: Pre-cat exhaust studs
  1. #1
    Registered Member
    2003 Mazda Protege5
    Join Date
    Apr 2016
    Location
    Baltimore, MD
    Posts
    104
    My downpipe (from pre-cat to cat pipe) flange on the cat side) broke off, and so I'm replacing it. I was able to get the old one off, but one of the studs in the pre-cat broke. It appears to be an M10x1.25 stud, but I have no idea how to get it out. I tried putting a nut on and welding it, but I can't get ANY penetration into the stud, probably because it's overhead and the weld pool wants to run away from the stud. As soon as I try to turn it with any torque the nuts just breaks free. Anyone have any suggestions as to how to get it off, and what is the appropriate replacement size? I've hard 35 mm is probably about right. If I can't get it off, how bad will the leak be with just two nuts, and is there anything I can do to seal it better?
  2. #2
    Registered Member
    Protege5
    Join Date
    Jan 2015
    Location
    Springfield, MO Area
    Posts
    961
    Drill it all the way through, and put a bolt and nut in it's place.
    The other option is to remove the manifold/precat and get a better weld onto the stud.
    2002 Protege5 5 Speed, Pure White, FSZE Swap, Konig Incident 17's
    2006 Chevy Silverado 1500 4x4 5.3
  3. #3
    I break stuff. Preferio's Avatar
    Donated: $1.67
    2003 Mazdaspeed Protege 1660, 2004 Winning Blue RX8, 2005 Mazda6
    Join Date
    Mar 2011
    Location
    Knoxville, Tn
    Posts
    3,812
    Quote Originally Posted by MrGiggles View Post
    Drill it out and extract it, install new stud.
    Drill it out completely, install bolt, nut and washers.
    Weld a stud to it, grind weld down.
    Purchase new converter assembly.
    Those are your options...
    ASE Certifications: A1, A4, A5, A8, C1, P2
    Mitsubishi-Fuso: Electr. Cert. 1, 2, 3 and 4
    2013 Mazda CX5 Touring
    2008 Mazda CX7 Touring
    2007 Mazdaspeed 3:
    2005 Mazda 6 S: Gone.
    2004 Mazda RX8: Gone.
    2003 Mazdaspeed Protege #1660: Gone and missed.
    2003 Mazda Protege5: Gone.
    2002 Mazda Protege5: Gone.
    1995 Mazda Miata Best $50 I've ever spent.
  4. #4
    Registered Member
    2003 Mazda Protege5
    Join Date
    Apr 2016
    Location
    Baltimore, MD
    Posts
    104
    I'm not particularly keen on removing the precat for fear I'm going to break another stud off in the process and just make matters worse. I guess its conceivable that I could try to weld from the above the nut although there isn't much room, but it might not have the same penetration problem.
    I saw someone drill into the stud before welding it, that might help, but he wasn't doing out overhead.
    The top of the stud area is a bulge, I'm not sure you could easily put a bolt through it, although its always possible I could drill and tap it.
    I'm not clear what the point of welding a stud to the stud would be. If I'm trying to extract it, I'd be better off with a bolt. The only advantage to a bolt or stud is that the pool may be more manageable, but it also seems like it's unlikely I could properly center it.
  5. #5
    ......................... i12drivemyMP5's Avatar
    Donated: $5
    323F
    Join Date
    Apr 2005
    Location
    Posts
    7,449
    Header.....
  6. #6
    Donated: $1.67
    Join Date
    Mar 2011
    Location
    Knoxville, Tn
    Posts
    3,812
    Quote Originally Posted by hpmaxim View Post
    I gave you your options, it's your decision. IT'S A BROKEN STUD, not brain surgery. Just remove the converter. It'll make your repair that much easier. If another stud breaks, so be it, at least it's out and easily manageable at that point.
Similar Threads
  1. Exhaust manifold studs
    By Tw1g007 in forum Protege5
    Last Post: 05-09-2016, 07:43 PM
  2. Exhaust Spring Bolt Studs?
    By zackmac in forum Protege5
    Last Post: 06-04-2014, 10:55 AM
  3. FS: Steedspeed Exhaust Manifold / ARP Studs / Vibrant Exhaust
    By Rogue in forum Completed Transactions
    Last Post: 11-03-2011, 08:35 PM
  4. ARP Exhaust Manifold Studs
    By Equinox in forum Mazda Protege
    Last Post: 06-06-2008, 12:08 PM
  5. exhaust studs
    By Fade in forum Mazda Protege
    Last Post: 03-07-2005, 10:31 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
