M mazdman 94MAZDAFD3S : 2015 CX5 GT AWD Liquid Silver Metallic/Black Leather Apr 23, 2017 #21 The OCV is part # PE0114420A and I believe dealer cost for just the valve is $280 or so. Add the other parts and labor and I'd guesstimate around $600-$700, plus probably a bunch of scraped off silicone in your engine, broken clips, etc.
M madar Contributor : 2016.5 CX 5 Touring AWD, 2015 SCION XB Apr 23, 2017 #22 Found the other post on this, again the OP noticed this at 57k miles. I was wondering why you had to replace the entire valve and not just a seal, but apparently this thing leaks internally as you mentioned per the TSB. https://www.mazdas247.com/forum/showthread.php?123848381-Small-Leak-on-Top-of-Engine-(Sensor-) Last edited: Apr 23, 2017
