Chuging at 3000 RPM and now check engine light is on
majicaleve
2009 Mazda 3 Hatchback Manual
Probably been asked a million times. But just signed up and need a quick reply instead of doing a search
Anyone able to help a girl out :(
BUT
Hope some idea's to what could be.
I see it might be injector issues.
I am on a budget and hope easy fix :(
"Chugging" could be a myriad of problems. For me these symptoms ended up as transmission failure, but i understand this is less likely with manuals. Could be a precursor to engine failure though. I would go into a certified tech/dealer service for diagnostics. I would not risk going to anotger mechanic. Pay the $100 for assessment by the right people.
Whens the last time you changed your spark plugs and have have you identified the cel code? A $5 bluetooth plig and a free ap for android can read codes. Otherwise places like autozone 9lwill often read codes free. If it's a misfire code most likely bad oligs ate the culprit l.
Before you assume anything, take a look under the hood. Look for split/disconnected vacuum lines and loose spark plug wire boots. Have that code read by an auto parts store (no cost).
