Hey folks. I just noticed a behavior and wanted to see if anyone has seen this with prior model years.
I use the auto hold feature, then continue with my drive. When I get to my destination I put the car in park and the parking brake comes on where my finger isn't anywhere near the switch. I can turn it off easily enough, but WFT? It does this consistently. Is this normal behavior? This is a 2017 CX-5 Grand Touring.
I've been going through my manual and while there are conditions where the Electric Parking Brake will enable, I don't think this is the case.
Under the following conditions,
the electric parking brake (EPB)
is automatically applied and the
AUTOHOLD is released. The
AUTOHOLD is re-enabled when the
conditions before the AUTOHOLD is
released are restored.
The driver’s seat belt is unfastened.
The driver’s door is opened.
When about ten minutes or longer
Which none of these are valid as the AUTOHOLD is turned off when I park. I'm not seeing any reason why this should be turned on when I park. The first time this happened I was freaking out thinking that I had been driving with the parking brake on. The second time I thought OK maybe I bumped the switch. This morning when I came into work I verified that nope, it just turned on, on its own. Thoughts?
PS- I've already called the dealership and talked with one of their service shop managers, he's going to go out and do some test driving to see if he can replicate this on another '17 CX5.
