Your Best Source for Genuine Mazda Parts!
Page 2 of 2 FirstFirst 12
Results 16 to 29 of 29
Thread: Mazda mobile start, anyone have it?
  1. #16
    Registered Member
    Contributor
    2017 CX-5 GT w/Tech Pkg
    Join Date
    Feb 2017
    Location
    Toronto
    Posts
    236
    In my last car, remote start would shut the engine off if the brake is pressed. That's a much better solution because you can't effectively steal a car without pressing the brake pedal!
  2. #17
    Registered Member Pipemajor's Avatar
    2017 CX-5, GT AWD w/Premium Pkg Eternal Blue Mica
    Join Date
    May 2014
    Location
    Minnesota
    Posts
    333
    My 2015 GT was a locate acquisition from another dealer. It had the factory fob-based remote start option for $500. Told my dealer I didn't want the option so he offered to split the cost. I've used it perhaps a dozen times over the past 3 years and still don't think it is worth it. No mobile app for the version I have so perhaps 150 foot range.
    I keep my CX-5 garaged so won't ever start it while in the garage unless I'm backing out the car immediately.
    My 2017 CX-5 GT definitely won't have it.
  3. #18
    Registered Member
    Mazda 6
    Join Date
    Jul 2016
    Location
    Parkville
    Posts
    41
    Quote Originally Posted by joe6864 View Post
    Yeah my viper alarm I had in my civic would do this.
    Sent from my iPhone using Tapatalk
  4. #19
    Registered Member
    2016 CX-5 GT
    Join Date
    Feb 2015
    Location
    New York, United States
    Posts
    127
    Has anyone considered Fortin EVO starter. I've looked at this:
    https://www.amazon.com/dp/B0047XSLLQ...I3COMJCVLB6RGL
    But haven't pulled the trigger. It uses your existing Mazda remote (triple click) to start. Cost is about $50 for the unit and about another $50 for the program used the program the unit for your car.
  5. #20
    Registered Member
    Mazda 6
    Join Date
    Jul 2016
    Location
    Parkville
    Posts
    41
    Quote Originally Posted by Ricsta View Post
    This company makes one for mazda. Taps right into the harness I believe. I found it the other day. Let me look back.
  6. #21
    Registered Member rickprins's Avatar
    2014 CX-5 Touring
    Join Date
    Feb 2014
    Location
    Waterford, MI, United States
    Posts
    33
    I put the Compustar CS-4102 in my '14 CX-5 Touring. This worked great all winter. As with the others, the car shuts off when the door is opened. I also have to use the Compustar fob for unlocking the doors after it has been remotely started. I was prepared for this and have no issues with it. Starting a warm car is way better than starting a cold car! The fob is slightly smaller than the OEM standard fob.
    I paid $259 including installation. You get 2 remote fobs. The primary is 2-way communications, and the backup is 1-way. The range is claimed to be 3000 ft. I haven't measured, but it's far enough for me to be able to start the car from inside the office. Since I also have aftermarket seat heaters, if I leave them in the On position I have a warm seat when I get in!
  7. #22
    Join Date
    May 2014
    Location
    Minnesota
    Posts
    333
    Quote Originally Posted by 7eregrine View Post
    Next was a Mazda option.
    Still listed right here on the accessories page:
    http://accessories.mazdausa.com/weba...Selected=vc254
    Dealer quoted me $550 for that. Will automatically hear or cool your car to a preset temp.
    ??EDIT?? If you select 2015 or 2016 that second option is listed. If you select 2017, it is not. Guessing this is no longer available for 2017's. REALLY LAME MAZDA. More options are always better.
    That's the one which came delivered on my 2015 which matched an available color (blue reflex mica) and trim (GT w/Tech pkg) for local inventory. Told the dealer I didn't want to pay $575 (MSRP) so he offered to split the cost and I took it.
    Range is limited and sometimes you get an ERR on the return confirmation although the engine did start and the FOB LCD indicates the engine isn't running. Easiest confirmation is at night with the headlights set in Auto. They'll come on when remote started.
    Supposedly it will turn on the A/C or rear window defroster if your climate control was set to cool or the ambient conditions warrant the rear defroster.
    Worth it? No. My office colleagues have the factory option on his Cadillac which seems to have much better range or the guy with an F-150 and the mobile start app.
  8. #23
    Registered Member 7eregrine's Avatar
    2016.5
    Join Date
    Jan 2017
    Location
    CLE
    Posts
    1,806
    3000 feet. Wow. That's nuts. LOL. Very cool.
    Seems like aftermarket I'd the way to go after the Pipemajor review. That fob is big too. Mine is tiny.
    Sent from my XT1585 using Tapatalk
  9. #24
    Registered Member
    2017 Mazda CX-5 GT PP
    Join Date
    Apr 2017
    Location
    NJ
    Posts
    2
    I just had a remote start system installed in my 2017 CX-5 GT with premium package. I used the following parts:
    FT-900S-HCF - Remote Start with 3X Lock with factory fob
    ADS-THR-MA3 - T-harness for easier installation
    DR-3400 - Drone mobile add on.
    I can confirm that the vehicle will remain running if you open the door. You have 45 seconds to get in the vehicle close the door and step on the brake. The door request switch will still work if you start the car with the drone mobile app. No need to unlock from the app. Very happy with the results. The installer told me that the firmware was updated within the past month to allow the vehicle to remain running after the door has been opened.
  10. #25
    2016.5
    Join Date
    Jan 2017
    Location
    CLE
    Posts
    1,806
    How much? Sounds nice but sounds like I can steal your car, too? No? Just step on the brake like I normally would to shift into gear.
  11. #26
    Registered Member
    16 CX-5 GT AWD w/ Tech
    Join Date
    Feb 2015
    Location
    Baltimore, Maryland
    Posts
    1,049
    Yeah I am interested in this as well. But wouldn't the car just be locked? I've never had a remote start in any of my cars but I would imagine the car would remain locked. Plus don't these units require the key fob to be in proximity before allowing the driver to shift gears?
  12. #27
    Registered Member
    Join Date
    Apr 2017
    Location
    NJ
    Posts
    2
    If you don't have the fob the car will shut off after 45 seconds. I paid $625 including the parts and install.
  13. #28
    2016.5
    Join Date
    Jan 2017
    Location
    CLE
    Posts
    1,806
    Quote Originally Posted by jhu8 View Post
    On my remote start, yes the car stays locked. Unlock the doors and open, car shuts off. Get in, start car. His works kind of the same but car doesn't shut off when door is opened. Having to start the car again doesn't bother me in the least, but nice to see there's an option if that does annoy you.
  14. #29
    Registered Member
    2016.5 Mazda CX-5 GS AWD
    Join Date
    Apr 2017
    Location
    Montreal
    Posts
    1
    I had this system installed when I got my CX-5 it's not branded Fortin, but it's made by fortin and branded for a well known windshield repair business in Québec, Canada. I have the 3x lock function and the cell phone option so I can start my car with my cell phone as long as my car is in Quebec or Ontario and I have internet access on my cell phone. There's no annual or monthly fees. It also cost a lot less than the mazda mobile start or the other remote starter that they offer. Works pretty well too.
    It sounds like an add, but I'm not affiliated with Fortin or the place that did the work. I'm just a satisfied customer.
Similar Threads
  1. New Mazda Mobile Start
    By cubanomx in forum CX-9 Lounge
    Last Post: 02-11-2017, 03:38 PM
  2. Mazda Mobile Start
    By Cis4 in forum CX-5 Audio
    Last Post: 04-28-2016, 08:56 PM
  3. Mazda Mobile Start
    By JewBilly in forum CX-5 Lounge
    Last Post: 10-14-2015, 01:53 AM
  4. Mazda Mobile Start
    By optical_man in forum CX-5 Accessories & Appearance
    Last Post: 09-01-2015, 11:06 PM
  5. Mazda Mobile Start ?
    By Panther in forum CX-5 Accessories & Appearance
    Last Post: 06-19-2015, 10:33 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
