Results 1 to 10 of 10
Thread: Trans Fluid
  1. #1
    Registered Member
    2007 Mazda CX-9 Touring
    Join Date
    Jan 2011
    Location
    new york city
    Posts
    668
    Question Trans Fluid
    Hi everyone. I would like to know which trans fluid would you prefer Toyota ATF I-V or JWS 3309. I would like your opinions based on which one is better considering everything including cost. All input is greatly appreciated. Thanks in advance.
  2. #2
    Registered Member
    2012 Mazda CX-9 Grand Touring FWD
    Join Date
    Aug 2012
    Location
    Houston, TX
    Posts
    74
    Six of one, half a dozen of the other.
  3. #3
    Registered Member
    Join Date
    Jan 2011
    Location
    new york city
    Posts
    668
    Is that what you did? how did that turn out?
  4. #4
    Registered Member
    Join Date
    Mar 2007
    Location
    Rivervale, NJ
    Posts
    97
    What's he's saying is that it's the same thing. JWS 3309 is a spec to which Toyota T-IV conforms. I have used Toyota T-IV numerous times, and it's fine. My local Toyota dealer gives me a discount when I buy a whole case, don't remember the exact price, but I always thought that it was a steal.
  5. #5
    Registered Member
    Join Date
    Jan 2011
    Location
    new york city
    Posts
    668
    Thanks phil. I will be going with the Toyota one for now. The mazda fluid is way to expensive. For the price of one qt of mazda fluid I can buy 2 quarts of the Toyota T-IV.
  6. #6
    Registered Member
    Mazda CX-9 Grand Touring 2016
    Join Date
    Sep 2016
    Location
    Washington, the state
    Posts
    231
    Check local auto parts stores for Mobil ATF 3309. Same stuff as T-IV. Check even Amazon and eBay.
  7. #7
    Biggie T Skinny helbigtw's Avatar
    CX-3, CX-5 & CX-9 Moderator
    08 CX-9 GT Fwd, Bose/Nav, BSM,Compass/Homelink, Pwr Lift,Tow
    Join Date
    Feb 2011
    Location
    Lexington, KY
    Posts
    2,047
    I have drained and re-filled the trans fluid once so far on my 08, and will be due again this summer. I bought the TIV from a Toyota dealer, got a whole box of it, and returned the bottles I didn't need. It was dirt cheap. I've towed U-Haul 6x12 trailers all over the country and hauled lots of stuff in my CX-9, and the transmission with 95k right now is still strong like bull, no issues. My vote is for the Toyota fluid.
    08' CX-9 GT FWD
    Gray Mica with Black Interior
    Nav/Bose/Sunroof/Bluetooth Phone/Rack&Crossbars/BSM/Pwr Lift/Homelink Mirror/Tow Pkg/All Weather Rear Mats
    K&N drop-in filter/Centric E-Coated rotors & Centric Posi-Quiet Ceramics /Yakima ForkLift Bike Tray / Weathertech front mats
    Tires: Nitto NT850+ CUV
    Oil: Mobile One Full Synth & Mobile One Extended Performance filter
    Problems to date: Blower motor relays replaced once, intake manifold rear brace was missing from factory build, headlamp motors are dying,
    windshield wiper plastic cap broken.
    Mileage: 94k Jan/2017
    Job: Auto Physical Damage Adjuster
  8. #8
    Registered Member
    Join Date
    Jan 2011
    Location
    new york city
    Posts
    668
    I am leaning toward the Toyota fluid also. How many qts came out when you did a drain and fill? did you do more than one or just the one that you mentioned in your post. The capacity is around 7.5 quarts for the whole system so I am guessing that for 1 drain and fill I would need about 4 qts.
  9. #9
    Join Date
    Feb 2011
    Location
    Lexington, KY
    Posts
    2,047
    Man it was awhile ago. I don't recall. Just drained, filled. I do remember having to buy a long hose and spout since the fill tube was so recessed.
  10. #10
    Registered Member
    Join Date
    Aug 2012
    Location
    Houston, TX
    Posts
    74
    Quote Originally Posted by kornholio View Post
    You are correct. Drain and fill is about 3.3 quarts so will need 4.
Similar Threads
  1. What type of Trans fluid should I use (manual trans)
    By Tom_Mazda2 in forum Mazda2 Lounge
    Last Post: 08-09-2012, 11:31 PM
  2. What would be the best trans fluid to use
    By BlkWidow in forum Mazda Protege
    Last Post: 03-24-2011, 09:33 PM
  3. Has anyone changed their trans fluid and/or clutch fluid?
    By krimsonviper in forum Mazdaspeed3
    Last Post: 06-20-2010, 01:27 AM
  4. Trans fluid how much?
    By StealthWyvern in forum Mazdaspeed Protege
    Last Post: 08-25-2009, 09:23 PM
  5. trans fluid
    By tylerh86 in forum Mazdaspeed Protege
    Last Post: 06-16-2009, 06:49 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
