CorkSport.com is MAZDA PERFORMANCE!
Page 1 of 2 12 LastLast
Results 1 to 15 of 25
Thread: Something wrong with right front brake
  1. #1
    Registered Member Izimo's Avatar
    Mazda Protege5
    Join Date
    Apr 2016
    Location
    Maastricht, The Netherlands
    Posts
    57
    Hello guys,
    Since I've owned my car there is something wrong with the right front brake. After some hard cornering and braking there would be a scraping sound as if the brakepads are worn, but this isn't the case and you can feel juddering in the brakepedal like if the discs are on there way out or crooked.
    When the brakepads where in for a change and I also wanted to put on new discs also I found out that there was on the bottom side a different bolt and there was a shim in between the caliper and the pad holder.
    I thought this was the issue with the strange noises and juddering and left it out when putting it back together.
    Now I still have the juddering when braking as if the disc is warped.
    Someone can tell what can be crooked and I have to replace and wtf could the 'shim upgrade' be?
    Thank you for reading!
  2. #2
    Registered Member Ban-Hammer's Avatar
    Mazda Protege5
    Join Date
    Oct 2016
    Location
    OR
    Posts
    44
    I get pulsing in my brakes, I know I have a warped rear rotor.
    I also sometimes get a little scraping noise, it's the pads rubbing on the rotors. A bottle of goop from Napa is like $6 and basically glues the pads to the caliper slide/piston, that way they don't rub when there's no pressure.
    Rotors are cheap at RockAuto. Replace the front ones and see what happens, worst case scenario you have new rotors. Or just pull the old one off and see if it's visibly warped.
  3. #3
    Mazda Protege5
    Join Date
    Apr 2016
    Location
    Posts
    57
    There is something warped, but it's not the disc. I think maybe something happened with the previous owner (hitting a curb too hard or something) and he bent something in the right front, but I can't see something crooked (upright, caliperholder etc.)
  4. #4
    Registered Member
    Protege5
    Join Date
    Jan 2015
    Location
    Springfield, MO Area
    Posts
    936
    Quote Originally Posted by Izimo View Post
    How are you so sure of that?
    Rotors are cheap, I'd replace them with the pads and start fresh.
    2002 Protege5 5 Speed, Pure White, FSZE Swap, Konig Incident 17's
    1998 Ford Ranger 2.5 5 speed
    1987 Mazda RX7, SBC swap in progress
    1998 Honda CBR900RR
    2013 Honda CB500F
  5. #5
    Mazda Protege5
    Join Date
    Apr 2016
    Location
    Posts
    57
    Like I said in the beginning, they are changed with new ones, but my issue is, why would somebody put a washer in between the caliper and holder.
  6. #6
    Registered Member
    Protege5
    Join Date
    Jan 2015
    Location
    Posts
    936
    Hello guys,
    Your first post wasn't clear if you did replace them or not.
    Was the washer between the caliper bracket and hub or between the caliper and it's bracket on the slider bolts?
    To my knowledge none of those are supposed to have a washer or shim. Got any pics of it?
  7. #7
    Mazda Protege5
    Join Date
    Apr 2016
    Location
    Posts
    57
    Quote Originally Posted by MrGiggles View Post
    I'm dutch, so forgive me for my bad English.
    The washer was in between cailiper and it's bracket on the bottom, at the top there wasn't.
    I don't have pictures, because the work was done a while ago, but the juddering stayed with and without the washer.
  8. #8
    ZOOOOOOOOOM ZOOOOOOOOOOOM mazdadude's Avatar
    '16.5 Mazda CX-5 Touring AWD, '05 PRIUS
    Join Date
    Dec 2005
    Location
    Red Bluff, CA
    Posts
    3,014
    What happens when the tires are in the air and you spin the wheel and tire by hand?
    What is the spare part you left out? You have called a washer and a shim... Do you have a picture of this leftover part?
    Did the other side of the car have the washer/shim?
    Have you looked at an exploded diagram to make sure you have all of the parts?
    When you installed the new rotors, did you clean up the hub flange too?
    Mazda's I have owned over the years.
    80' Mazda GLC SPORT MT - sold
    81' Mazda 626 DX MT - sold
    81' Mazda 626 LX AT - sold
    82' Mazda 626 DX MT - sold
    82' Mazda 626 LX AT - sold
    85' Mazda 626 LX MT - sold
    87' Mazda 626 GT Turbo MT - sold
    85' Mazda RX-7 GSL-SE MT- sold
    87' Mazda RX-7 Turbo 2 MT - sold
    91' Mazda Protege LX MT - sold
    92' Mazda MX-5 Miata MT - sold
    93' Mazda MX-3 GS-V6 Special Edition MT - sold
    00' Mazda 626 LX-V6 MT - sold
    02.5' Mazda Protege5 MT - sold
    06' Mazda 5 Touring AT - sold
    13' Mazda CX-5 Touring AT - sold
    14' Mazda 3i Grand Touring MT - sold
    15' Mazda CX-5 Touring AWD AT - sold
    03' Mazda Protege5 AT - sold
    16.5' Mazda CX-5 Touring AWD AT - current
    09' Mazda Mazdaspeed3 GT - current
  9. #9
    Mazda Protege5
    Join Date
    Apr 2016
    Location
    Posts
    57
    Quote Originally Posted by mazdadude View Post
    There was a washer in between the brake caliper and it's bracket. The kind of washer/shim you use between a bolt and surface you bolt something to.
    If I spin the wheel (and also when driving) all feels as it should. It only occurs when applying the brakes you feel the 'wobble'.
    On the leftside there was no washer and both bolts were the same, on the right side there was the washer and different bolt on the bottom.
    No parts left out I've done a lot of rotors and pads changes before and only thing I know is that a washer shouldn't be in that place.
    I've cleaned everything before mounting new rotors.
  10. #10
    Join Date
    Dec 2005
    Location
    Red Bluff, CA
    Posts
    3,014
    OK! Good to hear...
    RE: Odd bolt, Perhaps the previous owner stripped or broke the original bolt, and had to make do with another non standard one and added that washer then?
    When you say you "feel the wobble", where do you feel it? Does it do it when applying only the hand brake?
  11. #11
    Registered Member
    Join Date
    Apr 2007
    Location
    Cincinnati, Ohio
    Posts
    61
    Its probably your rear rotors. I had bad rear rotors and the steering wheel shook bad before I changed them out. Now I have no wobble with new rear rotors on.
  12. #12
    Mazda Protege5
    Join Date
    Apr 2016
    Location
    Posts
    57
    It comes 100% from the right front brake. The wobble is noticable true steeringwheel and brake pedal. Rear brakes is nothing wrong with them.
    That odd bolt story can be, but the washer where it shouldn't be was for some reason and with or without it. The right front brake wobbles. I will take it apart this week.
    At the red arrow in between there was the washer.
  13. #13
    Mazda Protege5
    Join Date
    Apr 2016
    Location
    Posts
    57
    I guess people are shocked about this
  14. #14
    Join Date
    Dec 2005
    Location
    Red Bluff, CA
    Posts
    3,014
    Still waiting to hear...Have you taken any pictures or taken it apart or had it inspected?
  15. #15
    Mazda Protege5
    Join Date
    Apr 2016
    Location
    Posts
    57
    This weekend I will take it apart and see if I can see something out of the ordinary, imho the reason would be that the wheelhub is bend or the padholder/caliper. I will also take apart the leftside to check for differences in the parts allignment.
Similar Threads
  1. Replies: 5
    Last Post: 11-12-2016, 08:05 PM
  2. Replies: 30
    Last Post: 11-17-2013, 12:27 PM
  3. Wrong Brake Pads???
    By ProbeChris in forum Mazdaspeed Protege
    Last Post: 08-24-2013, 12:49 PM
  4. CX-9 brake job - changing front brake pads
    By jediwebdude in forum CX-9 Wheels, Tires, Brakes & Suspension
    Last Post: 02-05-2010, 06:28 PM
  5. Front Brake Rotors and Brake Shields
    By IslandP5 in forum Protege5
    Last Post: 10-10-2008, 11:14 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
